Question about Canon BJC 5500 InkJet Printer
Colour/black cartridge is rejected
Black only (BC 20) works. When the loaded BC 21e is placed in the printer head it is rejected. It has happened frequently. I purchase new BC 21e's and they last 4 months. Where is the problem?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
I have a "BJC-4400" printer that has a cartridge holder for a BC20 cartridge. I'd like to replace it with a holder for both black and color cartridges. ~ Bob V
You will be able to replace it with a BC-21e cartrige adapter witch will hold colour and black cartriges in the same spot!
Here is an image of what it looks like:cbad7e0.jpg You will need to purchase the
BCi21BK Black ink tank 2af5c22.jpg and the BCi21C Colour ink tank
6ef4d60.jpg which are all available from http://www.stinkyinkshop.co.uk/acatalog/Canon_BJC4400.html
or your favourite ink provider source.
Jul 18, 2008 | Canon Office Equipment & Supplies
Can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Aug 05, 2009 | Canon PIXMA iP1300 Printer
Epson C46 - is it possible to set the printer so that it combines colours to produce black. My black cartridge just won't print, I've replaced it, cleaned it, power cleaned it. I know that when the black...
Printing black through color mixing is very expensive!
Try this:
Remove the cartridges and print head.
Make a moxture of 15-20% ammonia and warm water solution.
Soak the head for an hour then completely dry it ,especially the electrical contacts.
Run a cleaning cycle and see if your nozzle check pattern improves.
If so run another clean and recheck or soak it again.
Thanks for using FixYa.
Jun 20, 2009 | Epson Stylus C46 InkJet Printer
Error light and 6 beeps upon startup, therefore the printer won't print anything.
Is the BC-21e new, or refilled?
I know Cannon brand new cost so much more, but sometimes you have to bite the bullet.
I had a Cannon Multipass C2500.
Sometimes even a new cartridge isn't good enough. I used to exchange between that one and the all black cartridge, because the all black has twice the resolution. Even with very careful handling, not touching anything metal, they still went bad.
My best suggestion, short of another expensive cartridge is to remove the cartridge, take a soft pink pencil eraser and lightly erase all the contacts on the printer and the cartridge. Look for any of the spring loaded contacts in the printer that are stuck. Do not touch the contacts on the cartridge as they are unbelievably static sensitive. If you see ink on the contacts, use rubbing alcohol and a q-tip to remove it.
Most likely though, it will take yet another cartridge with head to fix it. (That's why I gave up on mine and got a different brand.)
Apr 13, 2009 | Computers & Internet
Only the Colour cartridge will Work. The Black doesn"t.
the black cartridge could be faulty. Try another new one. It is common to have faulty cartridges right out of the box.
Dec 04, 2008 | Office Equipment & Supplies
New Ink Cartridge
hmmm...what is the original? BX20? The BC 21 E is a generic for more than one printer. and you may find instructions on doing this at the www.usacanon.com site, under support.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Canon MultiPASS C70 All-In-One InkJet...
Parts
The BJC-55 takes 2 different types of print heads. And also a scanner head, that snaps into the same place and turns the printer into a scanner.
One print head is a Canon BC-11E. It has 2 ink tanks in it. 1 black and 1 tri-color. It prints in full color or black
The other print head is a BC-10. It prints only in black. But the ink yank holds 4 times the black ink of the BC-11E. It is very popular with business travelers who print only documents. The printer works about twice as fast with it. And replacing ink is a lot cheaper.
The scan head is called an IS-12.
Prices range from 40 to 60 dollars in supply stores ( Staples, etc)
Ebay is a good place to look for them
Oct 27, 2007 | Apple Canon BJC 55 InkJet Printer
HP Psc 1350 - cannot load black cartridge.
you still need the colour cartridge in place for your printer to function properly-then disable the colour through prefrences..
Aug 07, 2007 | HP PSC 1350 All-In-One Thermal Printer
Canon BJC 5500 InkJet Printer Logo
211 people viewed this question
old marine
old marine
