Question about Echo Blower Nozzle Es 2400 Pb 200 201 2100 21001420561
What is tke spark plug gap for echo PB-200 leaf blower
  • 430 Answers
.025-.030
Posted on Nov 12, 2012
5 Suggested Answers
  • 708 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
mowerman1857
  • 389 Answers
SOURCE: ECHO PB-650 Spark plug gap size
20 thousandths
Posted on Sep 16, 2009
Testimonial: "Thanks just what I needed great result thanks again"
  • 708 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
- how do I stop the piston from hitting the spark plug on my echo pb-251 blower?
You either have the wrong plug in it or the aluminium sealing washer is missing.
Feb 26, 2016 | Echo Pb-251 Leaf Blowers
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
My echo leaf blower will not start. How do I check to see if it is getting spark
Pull the plug out, connect it to the wire and lay the plug against the metal engine. Pull the starter cord and watch for spark at the plug.
May 15, 2014 | Echo Pb - 413t Backpack Blower
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
Pb-460 no spark
u could have a bad magneto, or u may need to check the gap on the magneto and the gap on your plug. pull plug and insert plug into wire and rest on top of head an pull starter to see if u get spark. if not, u need to check your magnetos gap.
Nov 04, 2012 | Echo Pb403 Pb413 Pb460 Pb4600 Carburetor...
SIR. I HAVE A ECHO PB 200 POWER BLOWER..WHAT IS THE FUEL GAS/OIL RATIO? THANK YOU
You can't go wrong with 25:1. Common accepted best ratio for this item to give best life for the internal components.
Nov 15, 2010 | ECHO, Inc. PB-251C Handheld Blower
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo PB-200 blower rope won't pull
try taking the spark plug out and see if it pulls then. if it got water in it, it could be vapor-locked.
May 21, 2009 | Echo Garden
Echo Blower Nozzle Es 2400 Pb 200 201 2100 21001420561 Logo
27,952 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
