Question about Invacare Pronto M51 Power Wheelchair
Wheel will not stay on Pronto M51 wheelchair. The bolt came out and put it back in, chair operates for little while then bolt will get loose again.
  • Mary Norman
    Mary Norman Nov 09, 2012
    the levels for the free wheel is engaged. it will operate for little while then bolt will get loose again and chair will not move forward or backward just turn in one direction. After tighten bolt again chair will operate for little while longer, then same thing again.
    An expert who has answered 20 or more questions within one hour.
  • 104 Answers
Use locktite on the threads
Posted on Nov 10, 2012
  • 40 Answers
SOURCE: My wheelchair Pronto M51 dose not move, the
Are the motors engaged? It sounds like it is in free-wheel
Posted on Apr 16, 2009
  • 175 Answers
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
Posted on Jul 09, 2009
  • 175 Answers
SOURCE: My wheelchair dose not move
The chair has two levers, one for each motor, that disengage it for freewheeling, or pushing the chair without power. These take it out of gear. Place the levers in the locked, gear-engaged position and it should go for you. Here's a link for the manual for your chair, and it will show you where the location is to place it in gear.
Posted on Jul 12, 2009
  • 103 Answers
SOURCE: My Pronto M51 chair does not seem to be holding a
Have the batteries load tested. It sounds like the batteries need to be replaced.
Posted on Oct 26, 2009
  • 103 Answers
SOURCE: control box on pronto m51 wheelchair don;t work
When you say "control box" I assume that you mean the joystick. If there is no power to the joystick be sure that the batteries are fully charged and be sure that they do not need to be replaced, also be sure that the cables were not put on wrong. If all that checks out then be sure that all the cables are tight.
If all these do not solve the problem then you need to have the joystick tested.
How do I reprogram my invacare pronto m51power chair
You will need to contact a service tech in your area to do this. They should have a special programmer box that can adjust the settings on the chair to improve the chairs performance.
May 02, 2015 | Invacare Pronto M51 Power Wheelchair
I get error code 9, what do I do to fix this
Error Code 9 is a "Communications Error". The controller, or "Little black box" down inside the chair is not talking to the joystick, etc. First, check all the connections. Unplug, examine and clean all of the connections going into the controller, and the joystick connection too. Inspect all of the cables for damage to the wiring. If all looks good, then you likely have a bad controller....ouch. These are very expensive to replace new. You might be able to find a used one on Ebay, etc., or you could be better off looking on sites like Craigslist for a complete powerchair replacement. I have found near-new chairs for under a thousand dollars. Search for Pride Jazzy chairs too...a lot more of those for sale than Invacare chairs. Good luck.
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
Reset button on pronto m51
There is no reset button on a M51 chair. Invacare puts fuses in the battery harnesses. The manual may say there is a reset but trust me there is not.
May 20, 2014 | Invacare Pronto M51 Power Wheelchair
How do u fix a pronto m51 wheel chair joystick after it got wet and it flashes 7 times
I would dry it completely and try it again. it may need to be opened and dried on the inside, or replace the joystick.
Strege Mobility
May 06, 2014 | Jet 3 Ultra Power Chair
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
How to move dead electric wheel chair
There are two levers, one for each motor, you have two. Depending on model either right under your knees (M51) usually, or under the rear, near the back casters. Typically black rubber on a metal rod. Move both in opposite directions, either both out, both in, or some types, both up, or both down. Sometimes they need wiggling, turn the chair OFF then try moving it in each position, (both in or both out). Google the manufacturer, your case invacare, they have detailed instructions there.
Jul 08, 2012 | Invacare Pronto M51 Power Wheelchair
My laft wheel hancs up. mostly when turning left and feels like the brake is sticking. It will hang up bad enpugh that the chair will not move and the safety lights are blinking when I try to move. After I...
Sounds like you need to replace the left electric brake. The brake is on the opposite end of the motor-gear assembly from the motor. Remove the screws holding the brake on to the gear assembly, unplug it and replace with new brake.
Dec 19, 2009 | Invacare Pronto M51 Power Wheelchair
Where is the reset button on a invacare m51
The controller puts out fault codes though the LEDs. Count them and then look in the operators manual for likely causes. In my experience it is the electronic brakes that fail on these units and they are costly.
Oct 04, 2009 | Invacare Pronto M51 Power Wheelchair
How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Mar 28, 2009 | Invacare Supply Group Invacare Pronto M51...
Invacare Pronto M51 Power Wheelchair Logo
76 people viewed this question
Top Invacare Health & Beauty Experts
Colin Taylor
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
