LIGHT UNIFORM STREAKS ACCROSS PRINT
I have a Canon Pixma pro 9000 which is exibiting parralel streaks accross the print. they are the right colour but lighter. I have deep cleaned the head and aligned the print head but to no avail. the lines are about 2 mm apart and are the same no matter the size of print.From what I can see all cartridges are working corrctly. Is there any thing I can do??kind regards.... bernard
  • Anonymous Jan 26, 2009
    Same thing here. Also in splatter. Canon even sent me a brand new head and it's doing the exact same thing. Sigh
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
My Canon Pro9000 MarkII prints photos with a red tint
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
Dec 29, 2012 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon pro 9000 printer -green tint on all prints
theres an option in the printer options. if you have run the clean printer head option then you may need a new printer head
May 03, 2012 | Canon Pixma Pro 9000 Mark Ii Inkjet Photo...
Canon pixma pro 9000 - when printing the paper goes in a couple of cm and gets caught (on the right corner) and tilts to the left side I can hear the rollers spinning but printing ceases
Hello! To solve your problem follow the instruction. 1. Paper must be straight, don let them curve. 2. Paper must not wet, should be tried. That is the only way to solve problem.. good luck
Sep 09, 2011 | Canon PIXMA Pro9000 Printer
My canon pixma mp 610 prints a colour picture with lines running accross it. I have tried cleaning the print heads but with out successs Can you Help
Try taking the cartridges out one by one & clean the contacts on each one with a little warm water on a small piece of cotton,check that none are leaking, bulging or have any tape over air holes. Then replace. I did this and it worked OK.
Sep 30, 2010 | Canon PIXMA MP610 InkJet Printer
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
You need to check your nozzle check print and see if all the colors print. Also many generic inks are not the right color. Take out your yellow cartridge and see if it's still yellow, if it's orange or brown you need a new printhead, there's a membrane inside that keeps the colors separate and when it breaks you get cross contamination of the colors.
Dec 23, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Canon Pixma iP6600D - ink problems
Use original cartridges. Generic or refilled cartridges tend to cause these problems.
Oct 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
154 people viewed this question
jasbo
jasbo
