When i hook up cable and press scan its not going to digital mode
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Check the model with Google for specs to see if the set has a built in digital tuner or not.
Posted on Nov 07, 2012
Hooked up to antenna did channel scan in air mode not getting any channels. Hooked up a Vizio tv to same antenna line and got all the locals. Maybe something wrong with the Sharp?
Make sure that Sharpe is set to over the air/antenna and not cable. There are more than one scan modes. http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC42_46_52D65U.pdf
See page 14 in the link. It is easy to mis-configure the setup to not receive the over the air digital channels. The input must be set to digital and air in setup. The VHF are no longer available.
Hope this helps?
Jan 15, 2016 | Sharp LC-32DA5U 32 in. HDTV-Ready LCD...
I have a Westinghouse DWM32H1Y connected via coax to cable. Auto scan will not pickup digital channels. Can someone help?
Only suggestion I have is to make sure you are in the correct mode (ANTENNA if you are hooked-up to a regular aerial, and CABLE if you are hooked-up to cable).
May 14, 2015 | Westinghouse Televison & Video
How do I program my RCA LED48G45RQ HDMI to digital channels
Several things to check. First go in the menu where u are doing the channel scan and see if there is a separate line that says digital and if so select it so it can add those channels. Next look also on the remote and see if there is a button that says ANT or Input and press it to see if selects the digital side. Next see how u are hooking up the set from either cable, SAT, Antenna, etc, and are u going thru the antenna connection/the screw on cable input. Cause if going thru hdmi or any other input will not allow u to scan channels. Next the tv may not have a digital tuner in which some new sets don't, look in owners manual and read on channel programming and it should tell u. Maybe something here will help.
Dec 09, 2014 | RCA Televison & Video
How do I set up my tv, for auto scan I thought I needed a digital converter, I just learned that I do not. Do I need an antenna of any kind at all. I am very confused. I really would like to talk with...
If you are trying to program free HD off air you will need a UHHF antenna attached to the ATSC hook up on back of TV then have TV scan for channels available. If you are hooking up a "cable" box or satellite receiver that will just get hooked up with the output of the box going to an appropriate input on your TV. If you are just taking a cable from wall (being used as an antenna) then hook that up to the QAM antenna connection on tv and scan for channels once that is hooked up.
Hope this helps - if not please be more specific on what you are trying to hook up to what input.
Mar 08, 2011 | Televison & Video
How to Chanel Scan
Tv is hook up to cable tv or free DTV air broadcasting?Have a good antenna source hook up or cable or satellite signals.Go into the tv menu go to SETUP.Go down to CH. press enter pick Cable or Air.Enter for scanning,after it done scanning will get all free DTV air or cable broadcasting channels stations signals.
Feb 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
How can we view cable TV when the TV doesn't have a tuner?
Ur tv is a digital tv.Just buy a Digital antena or a roof antena hook it up.Go to SETUP menu go down to CH. SETUP pick AIR,not CABLE and than enter to scan.After ur tv done scanning,u will get all the free air DTV channels.
May 01, 2010 | Olevia LT37HVS 37 in. LCD HDTV
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
Can not program my cable channels
move your antenna around to get maximum signals to be able to scan.
Jul 02, 2008 | Real Digital RD2200 22 in. HDTV-Ready LCD...
Have sound,no picture
Do you have it hooked up using the component cables?(red, blue, green cables?) You need to use the component cables to use the progressive scan feature. So if you have it hooked up using the yellow rca jack, you will have to switch cables.
May 30, 2008 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
