Question about Acer Computers & Internet
Ntfs local c is in ntfs mode
  • max carson
    max carson Nov 07, 2012
    Is C working?
  • Acer Master
  • 2,878 Answers
You may be loading an application looking for NTFS, but your system is FAT or FAT32 if Windows. MACs and Linux based systems may have formats and will not support some Windows based files or applications.
Posted on Nov 07, 2012
In Apple I can see 5 folders in there. But, in PC System 10, I only see a folder name local and a data base file name log. I didn't find my songs.
What is a P.C System 10 is this a Windows 10 operating system.
Suspect your five folders were created in Apple Format and Other P.C's that are not Apple can't recognise it. You may be able to create folders in NTFS folder file format from the Windows 10 system that Apple may be able to Read.
read the article below on how Mac can write to NTFS file systems
http://www.howtogeek.com/236055/how-to-write-to-ntfs-drives-on-a-mac/
Jan 03, 2017 | Apple Audio Players & Recorders
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
Driver ntfs
you can try to run SFC.open the command prompt (cmd) and run SFC as a administrator write.SFC / SCANNOW
or run checkdisk also as a administrator.
write. CHKDSK /F/R
DO YOU GET INTO WINDOWS,TRY SAFE MODE IF NOT.
Jun 25, 2013 | Compaq Computers & Internet
WHAT DOES NTFS STANDS FOR?
Have you tried a System Restore/Recovery? Can you boot in safe Mode? Have you removed and tested the HDD? Do you have a Windows Repair Disk? How old is the Machine? May be time to replace the HDD? Has the Machine been losing time when you restart after a long shut down? Try replacing the CMOS battery. NTFS: http://en.wikipedia.org/wiki/NTFS
Mar 20, 2013 | Dell Optiplex GX270
Hi, I had problem using Imation 27390 apollo expert ux. The hardisk is in NTFS format, and work perfectly fine when i plug in computer with Windows Vista and 7. But it cannot be recognized by computer...
Windows XP has limitations on recognising too large NTFS disks. One of the solutions would be to format the entire disk as FAT32 or make a partition and format that as FAT32.
Feb 28, 2011 | Imation 27390 Apollo Expert UX 2.5" 320GB...
Pls i need help.. i have a western digital external 320gb sata 2.5" hdd, i connect it to my pc via usb. I split it into two partitions one as Fat32 and the other as NTFS, which has been running very...
When you power up the computer press F8 key then enter in safe mode. Then open my computer if you are able to see all partition then take backup of all data. If you are not able to access ntfs then right click on my computer icon click on manager then go to disk management and select your removable drive then right click on ntfs partition and tack bakup of all data then format it . then you can use it again. Also make sure on harddisk for jumper settings. Let me know if you need further assistance. thanks for using FixYa.
Dec 07, 2010 | Computers & Internet
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
Humax pvr can not read my maxtor 500gb harddrive why is that?
NTFS
1)allows access local to w2k w2k3 XP win NT4 with SP4 & later may get access for somefile.
2)Maximum size of partition is 2 Terabytes & more.
3)Maximum File size is upto 16TB.
4)File & folder Encryption is possible only in NTFS.
FAT 32
1)Fat 32 Allows access to win 95 98 win millenium win2k xp on local partition.
2)Maximum size of partition is upto 2 TB.
3)Maximum File size is upto 4 GB.
4)File & folder Encryption is not possible.
I hope this clears things up for you
Mar 08, 2010 | Maxtor Hard Drive
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
No boot up
Solution :
  • Run chkdsk /r or chkdsk /f to detect and resolve any file system structural damage.
  • After you use the Chkdsk tool to repair the corrupted NTFS volume, rename %SystemRoot%\System32\Drivers\Ntfs.old to Ntfs.sys, and then shut down and restart the computer.
  • Try disabling any virus scanning programs, backup programs, or disk defragmenter tools that constantly monitor your computer.
  • Run any system diagnostics that are supplied by your computer manufacturer, especially a HDD check.
Jun 06, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
