Question about Phonic Audio Players & Recorders
My Phonic Powerpod 410 PA doesn't work
I bought a Phonic Powerpod PA system off of musiciansfriend.com brand new and it wasn't working what so ever. I have also passed the point of return and do not have a warranty for it. Would this be an easy fix from home or something I need to take to a professional to be repaired or am I stuck with a $200 paper weight?
SOURCE: Phonic Max 2500 blocked/protected
the problem of shuting down of amp. is some of output driver are shorted or open check the output driver and predriver
Posted on Mar 13, 2008
marsrover
  • 682 Answers
SOURCE: I just bought the Antares
please connect output from vocal producer -to ch1 to ch6 hi-z input in your phonic.
Posted on Jul 18, 2008
robotek
  • 1512 Answers
SOURCE: connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Posted on Aug 18, 2008
  • 29 Answers
SOURCE: how can I connect my P.A. system to pur phone
This is very tricky unless your phone system has an analog audio line input provision. It's almost impossible to introduce external audio ( from your P.A. system ) into the phone system when a phone is on hold unless the PBX system has an external audio line input. If it does, all you need is a standard 600 ohm to 600 ohm audio transformer where you connect your P.A. systems preamp signal out to one side of the transformer and the other side of the transformer to your PBX systems external audio ON-HOLD line input.
Posted on Sep 01, 2009
  • 4 Answers
SOURCE: radioshack 250 watt pa amp stopped making sound
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Posted on Nov 14, 2009
I have no sound
you should open it and look for burnt components like capacitors. they can usually be replaced.
Jun 23, 2014 | Phonic Powerpod 410/S710 Pa Package
I tried hooking up a laptop to powerpod mixer it shows music is playing but nothing comes out of the speakers
Which inputs are you using? If you are using the 2T RTN, you will need to engage the 2T RTN button under CONTROL ROOM SOURCE and engage ASSIGN TO MAIN.
Sep 27, 2011 | Phonic Powerpod 820 / S712 PA Package
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
Hi, i have the powerpod 820 and i turned it off abrubtly and now the audio wont go throught like on the right where the green lights are for the audio nothing is lighting up what could be the problem?
After seeing a LARGE number of the Phoniic things listed for sale as defective, I suspect the amp has a failure and requires repair in a shop unless you are adept at electronic repair. There probably is a design weakness in the unit to have the high failure rate.
Jan 29, 2011 | Phonic Powerpod 820 / S712 PA Package
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
What is the ideal speaker specification to match the 8 channel Phonic Powerpod 820. is it possible to play live gig using this set up ? what is the maximum possible set-up ?
to get the best from this mixer output wise, you need to use 4ohm speakers rated at 150watts each. The 200 wat rating is at 4ohms. You can use 8 ohm speakers, but they recomend speakers at 70watts.
Gig wise, you could do a small location that will cater for about 40 people, but that would be pushing your system to the max.
Maximum possible set up? well there is a way to work most scenarios you are given, but it is not best practice.
Ideally, you know what instruments and vocals you want to go through the system, a rough idea of the size of venues you wil play and then ask questions on a system to suit.
Jan 12, 2011 | Phonic Powerpod 820 / S712 PA Package
Top Phonic Audio Players & Recorders Experts
Greg Cann
Greg Cann
rhodesworks
Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
