Question about Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre monitor will not return from idle.
I have a Sceptre X20g-Naga III 20.1" LCD Monitor and a Radeon x800 AGP graphics card but the monitor will not return from idle or come back on after I turn it off. The only way to get the DVI working is to restart the computer. I've purchased multiple DVI cables and reinstalled the drivers countless times. I've tried the Catalyst Control Center and just the display drivers but nothing fixes it. I've even reformatted but I am still unable to turn my monitor off and then back on or let it go idle. This problem seems to only occur with Sceptre monitors and ATI cards occasionally and I've noticed some people have solved it in various ways through driver issues but for some reason it has not worked for me. Any help would be greatly appreciated. -Sean
  • Anonymous Jan 04, 2008
    I HAVE THE SAME PROBLEM, IT DOES NOT COME ON AND I HAVE UNPLUGGED IT AND THE STAME RESULTS
  • Anonymous Dec 29, 2008
    I have an nVidia 7600GT and have the same problem. If I make sure that the power never turns off the monitor it will work all day, If I re-boot, I have to turn it on and off several times until it stays on. I've had it on for as much as 14 hours with no problems. Someone posted a fix, but it's not a fix at all, it's BS! Sceptre says it's the backlight Driver board. They charge a Flat Rate $75 to refurbish it. Since they are close to where I live, I may well do that since I can't buy as I can't buy a new one that cheap.
    John Stephen
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
Posted on Aug 27, 2008
Why does the Little Green Light on the front of my Monitor just Blink and the Monitor will not come on ?
The monitor is not getting any "signal" from the video-card.
Check that the video-cable is connected to both the monitor and to the video-card.
Try connecting the monitor to a different desktop/laptop,
to see if the monitor works "elsewhere".
Try connecting a different monitor to your desktop, to see if the video-card is the problem.
Sep 18, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X22 Naga Will not power up.
Start looking at the power supply for bad caps, see some example of a couple yeras old monitors that failed due to cheap caps being used: http://s807.photobucket.com/home/budm/allalbums
Jan 08, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20
reinstall your video card drivers ,
Nov 16, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20G Naga III showing horizontal and vertical lines
Hi...there,
Yeah, there it... It's called a AD board. It that piece of component were you plugged your VGA or DVI cables to it. Panel scratchs repair kits, not recommended. Beside your panel could be already damaged by this problems you had. Replacing the AD board gonna cost you though...any where from $70.00 or more... My recommendation, just get a new one...saved you the headached and $$$.
Have a nice day!
May 02, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
283 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
