Question about Dishwashers
Not cleaning properly
Dishwasher tablets do not dissolve and therfore dishes and cutlery are not cleaned properly.
    Problem Solver:
  • 8 Answers
You could be using the dishwasher at a higher temperature than the biological agents in the tablets can handle, and so become denatured and can't clean your dishes properly. I have had this problem a little while ago and found that using the "eco" setting (should heat the water to around 30c and has the added bonus of using less water) works well and makes sure that all of the dishes are clean.
It could also be a problem with the release system, where the door the holds the tablet can't release it on time and so the tablet does not dissove. Have a check to see if anything is stopping the door opening and see if there is anything you can do to make it release on time.
Hope this helps,
Posted on Jan 05, 2009
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
My diplomat dishwasher is not dissolving the tablets even on a hot temperature, what can i do?
Check if the circulating pump is actually working - are the dishes being cleaned at all ? If not - check pump for operation and replace if faulty.
If tablets are still stuck in a compartment - replace operating mechanism for tablet drawer, or - cheaper - put tablets in with the cutlery instead.
Aug 20, 2010 | Dishwashers
ADG6340 not washing well. Now tablet doesn't dissolve sometimes.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 14, 2010 | Whirlpool 24 in. ADG6340 Built-in...
Not coming out clean
I'm guessing from your post that your cutlery is the only thing in the dishwasher that is not getting clean, but rather with that nasty coating when you go to empty it. The reason for this phenomenon doesn't lie in a problem with the dishwasher, but rather a simple chemical and physical reaction between the dishwashing liquid (or powder or tablet), heat from the dishwasher's dryer, and the metal on that set of cutlery. The bleach from the dishwashing detergent will work very hard at getting your glasses, bowls, and everything glass and/or plastic clean and sparkling because it contains bleach in its ever-proprietary mixture of citrussy goodness. Unfortunately, metals and bleach, combined with heat are NOT a good combination! The best advice I can give you in this case (again, assuming that everything else in your dishwasher is looking fabulous and that your cutlery is the only thing that is not) is to wash your cutlery by hand with regular dish soap in the sink and do not put them in the dishwasher. Of course, it's easier to just stick all of that stuff in the dishwasher and not wash it by hand! It's why you bought a dishwasher in the first place, right? But if you want your cutlery (especially if it's GOOD cutlery) to look good and perform well, your best bet is to wash it the good ol' fashioned way...In the sink.
I hope this helps! :) Let me know if you need anything else that I can help with.
Sep 21, 2009 | Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Everytime I put dishwasher on the tablet doesnt dissolve and
Hi there, always rinse the dishes immediately after use before putting them in the dishwasher. Also make sure they are not too tightly stacked, as this prevents proper cleaning.
Apr 09, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Dishwashers Logo
387 people viewed this question
Top Dishwashers Experts
