Question about Exercise & Fitness
When i walk or run on it ,the big running belt sqeaks. Its a norditrack c1900 series
    Top Expert:
  • 12,223 Answers
1) LUBE the deck belt, this happen because the lack of maintenance schedule .
2) LUBE the rollers bearing too very well.
3)test the main motor, for bearing lube
4) If the problem persist, you have a problem with a worn deck, replace.
God bless you
Posted on Nov 07, 2012
2 Suggested Answers
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Nordic c1900 belt stops after a couple of minutes
please lube the deck belt with silicione or wax read your manual. See the video attached. If after you lube the problem remain. Time of replace the deck belt board completely.
God bless you
Feb 16, 2013 | Exercise & Fitness
When I start car it makes a loud sqeaking noise what is that?
either the belt is worn and causing this or one of the pulleys on the motor may be causing this if the belt is good remove the belt and test the diff pulleys by spining them with your hand wiggling each one and see if they are loose. hope this helps
Jan 25, 2011 | 1990 Chevrolet Cavalier
Walking belt on NordicTrack C1900 is to loose, how do I tighten it? When walking on it when u get to level 4 it just about throws u
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
Sep 30, 2010 | Nordic Track NordicTrack Treadmill, A2550
Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Feb 05, 2010 | NordicTrack Exercise & Fitness
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Sep 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
I hear a sound like the fan belt sqeaking, I know there is only one belt and that belt is still on . first it made a sound like a tire was leaking air then i heard the sqeaking under the hood
belts can still sqeak even though they are still on, check the condition of the belt, is it craked?, glazed? spray some silicon spray on it while its running and see if it goes away. the belt driven accesories can also make noise, alternator, steering pump, water pump, idler, tensioner, a/c compressor. use a long screwdriver like a stethescope and see if one belt driven acessory makes more noise than the others, just be careful of moving parts.
Mar 16, 2009 | 2001 Ford F150 Styleside SuperCrew
Exercise & Fitness Logo
77 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
