Samsung top loader 5e error - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
5E= WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Posted on Nov 07, 2012
blueextc3221
  • 15935 Answers
SOURCE: de error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: Samsung B1245 front loader
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Posted on Sep 16, 2010
PSITECHNICAL
  • 71 Answers
SOURCE: getting error 5e WF7708 samsung front loader. Have
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Posted on Jan 06, 2010
Testimonial: "i was draining the water out only coming out in dribbles so i think you hit the nail on the head....ty ty will give it a go..."
  • 6277 Answers
SOURCE: I have a samsung B1045AV
Before thinking about actually changing the motor follow my guidance notes below ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 21, 2011
SOURCE: Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Posted on Feb 01, 2012
My top loader washing machine shows SE. Please assist.
Hi!
I has the same 5E mistake with my Samsung washing mashine.
5E looks like SE on the screen, but it is 5E.
This is what the manual says:
5E - Your washer is not draining. It can
also mean that the unit senses a
small clog while draining
Do the following:
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
Apr 26, 2017 | Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
7kg 1045 front loader, says SE or 5E wont drain, will open fill and wash but not draining
Hello & Welcome to FixYa
5E is a water drain error and occurs when the water level frequency does not show changes. First clean the debris filter located at the bottom of the washer and then turn the unit back on after 15 minutes. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Samsung Washing Machines
Error code se on samsung front loader 7kg
could the code be 5e if it is a 5e then the problem would be
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON. Another tech has also done a previous post to this subject so click here to see her repair as well http://www.fixya.com/support/t5093804-se_mean note that if this repair does not work please message me back and there will be other tests for you if this repair she lists does not work if you have any further questions also message me back with them and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Mar 16, 2011 | Samsung WF337AA Front Load Washer
I HAVE BOUGHT SAMSUNGWA80V3 TOP LOADING WASHING MACHINE. I AM GETTING ERROR 5E and WATER IS NOT DRAINED OUT.PLS ADVICE.
this error comes if waste water pipe jammed or blocked
2. WATER DRAIN ERROR - Display shows 5E.
check the drain pipe that comes out the back of your machine
please message me back if this does not solve your appliance situation and please remember to rank how this opinion has helped Thanks again
Rick
Nov 09, 2010 | Samsung Washing Machines
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
Jan 06, 2010 | Samsung Washing Machines
Error Caode 5E - Machine not spinning
Can you get me the model number? Thank You!
Jun 19, 2009 | Samsung Washing Machines
Washing Machines Logo
204 people viewed this question
Top Washing Machines Experts
