Yellow Spot on Dell IN2020M monitor due to heavy exposure of 100w bulb how to remove that?
Actually my monitor was stuck with little water so according to solution in online i kept a 100w bulb about 3cm gap between monitor and bulb up to half-an-hour.the monitor was off when i put that light after that then i saw a black big spot around 5cm diameter when i removed light i began to decrease slowly after that i turned monitor i noticed a yellow spot due my fault and over heat the remaining part of display was excellent suggest any solution or can replace led inside it or i can remove it thanks in advance pls reply to charuwaka@gmail.com
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 137 Answers
No you cannot replace an individual LED, it's simply too hard for yourself to do it. The led is a sheet of led diodes and to replace one is very difficult, requiring lots of soldering etc. You should get it to a repair shop where they have spare exchangeable panels which is easier to replace. Also the yellowish colour is probably due to the pixel itself being burnt, not the LED light.
Posted on Nov 07, 2012
  • 1 more comment
  • charuwaka
    charuwaka Nov 08, 2012
    Thanks for reply that means by changing the back pannel can i solve my problem pls confirm it where i can i find back pannel for my dell 20-inch monitor and also fund the yellow spot appears only when background color is black rest of colors it mix up with them
  • charuwaka
    So can i fix this problem by changing back side panel please reply antony
  •  Anthony Tsoi
    Anthony Tsoi Nov 08, 2012
    I would find the panel model of your monitor and google the same panel for maximum fixability. Yes, it's not your backlighting, it's your pixels being burnt slightly. Best way would be to send it to dell or a repair shop for repairs as they will have the correct panels. But if you want to DIY, you can purchase a panel online after you find the type of panel inside, I don't know which site you should get it from, but beware of scams!
SOURCE: Xerox XG-91D 19 in. Flat Panel LCD Monitor
Just tore mine apart so here is some help. You need to remove the two screws on the back of the case on the bottom. Then you remove the front cover it slides toward the top of the screen then lifts off. You can pry it off if that doesn't work. If you want to seperate the screen from the back cover you then need to remove the swivel mount and the other two screws from the back cover.
Posted on Jan 04, 2007
SOURCE: samsung 45bn
hi... there's a resolution problm with samtron45Bn with win xp.
Pl.help to fix this pblm.
Posted on May 27, 2008
SOURCE: Monitor displaying yellow tint
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
http://www.mydigitallife.info/2007/07/11/windows-vista-photo-gallery-yellow-tint-background-problem/comment-page-2/
http://www.walkernews.net/2008/07/15/how-to-fix-windows-photo-gallery-yellow-tint-and-photoshop-monitor-profile-problem/
Posted on Jan 29, 2009
TampaNative
  • 778 Answers
SOURCE: Monitor blacks out...
You could connect it to a different PC to determine whether it's the monitor or video card, corrupted driver, etc....
Let us know how it goes, and we'll try to help.
Posted on Feb 08, 2009
  • 286 Answers
SOURCE: My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Posted on Sep 15, 2009
How do I unlock my dell in2020m monitor screen?
Press and hold the button above the power button for 10 seconds. You can download the manual here... http://www.manualslib.com/manual/506179/Dell-In2020m.html
Jul 21, 2014 | Dell Computers & Internet
My dell IN 2020 M monitor goes off after 4-5 min...i tried reducing brightness to zero ...it worked just for one day but now again the same problem starts....plz give some suggestions...
Dear Kumar, First of all make sure your laptop is not getting extra heat?
and most probably this issue is with your Graphic Chip.
you have to take it to any hardware export.
PS: Its recommended to visit Dell Authorised Service Center, otherwise this issue is much sensitive and will keep coming after few days even after the chip replacement.
Nov 02, 2013 | Dell IN2020M Monitor
I have a 52" LCD
Can you still see the spot when the TV is off? In any event, the screen may have something on it or the mirror that reflects the image from the projector where the bulb is. Make sure the projector bulbs are clean. Good luck, thanks for using FixYa.
Mar 03, 2011 | Zenith E44W46LCD 44" Rear Projection...
How to check high power amps by using bulb series technic
You can use CFL (Compact Flourescent Lamps)
100W CFL is cooler and brighter than the standard 100w bulb. Therefore, for the same performance, a 60W CFL is equivalent to the
100W bulb.
Sep 22, 2009 | Audio Players & Recorders
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Looking for replacement parts for vector spot light
The bulb you are looking for to fit these vector spot lights is an automotive bulb, and H3 with a PK22s base. They come with a cable and a nickle size disk at the base of the bulb. They come in several wattages, eg 55w and 100w. Try the "bulbs.com" website, in their search box type "H3 PK22s" and you will see they have a variety of wattages and voltages. Be sure you buy a 12V for these spot lights. They come with a cable and nickle size disk at the base of the bulb. Hope this helps. From Uncle Ray
Oct 06, 2008 | Camping, Backpacking & Hiking
Laptop problem
the water damaged the screen ....no way i know to fix it sorry :(
Jul 14, 2008 | Computers & Internet
Black out in corner of screen is growing
If You see that black spot while monitor is off then the LCD needs to be replace. if not then check these....
Check the LCD panel (push a little bit from the black spot place if it loose colours then may be it is due to the improper connection with panel board.( check the voltage while changing the screen resolution, if everything is ok then......
LCD pixels burned. replace the LCD panel or if u want to use it as it is then decrease the brightness and don't use high resolution images.
Dec 21, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
385 people viewed this question
David Payne
David Payne
