Question about Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive
I have a Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive. It uses a split USB connector with one being power & data and the other being power only. It worked once on a co-workers laptop and has not worked since. I have plugged it in to several different computers, into known good usb ports and there is absolutely no response from either computer. There is a led on the hdd which blinks once. If I leave it plugged in and come back later, this led is on continous. I am not concerned about salvaging the contents, we have other copies. I just want to be able to use the drive. By the way, you can hear the hum of the platter(s) spinning and on first plugging it in you can hear some head activity. I have looked in the device manager as well as in disk management on each different computer and ther is no sign of this drive/ Any ideas??
  • michelm Jan 20, 2009
    I reinstalled Vista Ultimate (without formating) yesterday and without the drive plugged-in the usb port, restart computer this morning, plug in the drive, no way to get the drive recognized. Vista is asking for the driver and the manufacturer does not provide one... Until then, I thought I had the best usb smart key out there...
    -mm
  • 32 Answers
First let's try going into disk management and see if we can see your maxtor drive. Plug it in then right click on my computer. From there click on manage and then select disk management.
This will give you a list of your drives. If the Maxtor is there, what is the status? Can you right click on it and activate it? If you don't see the drive then let's try the next step.
If you go into your device manager and select your Universal Serial Bus Controllers. Right click on your on the USB Universal Host controller and select uninstall. This will uninstall the USB Driver, but don't worry, oncfe you have uninstalled all the controllers, you will reboot the machine and then Windows will come back and reinstall all the usb controllers. Once this is complete then plug the drive back in and see if you still get the same issue. If none of that works....
Download a linux bootcd called SLAX http://www.slax.org/get_slax.php?download=iso
use nero to burn the iso to a cd and boot from it. Once you're in there, you SHOULD be able to recognize or at least see the drive. If you can then format the ****** from Slax. Once that's complete, you should be able to see it as a raw drive in Windows and then you can format it using explorer or a command prompt.
Let me know how this goes.
Posted on May 05, 2009
I cant find sofotwaer Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-mini&vgnextoid=7fd5783de3444110VgnVCM100000f5ee0a0aRCRD
Nov 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
My maxtor onetouch 4 mini 160gb didnot open help me
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Any computer i connect to it is not accessing the data, but it recognizes that it is there. I just want it on long enough to move data to my computer.
you have to "mount" the hard drive..... search that terms out in conjunction with your operating system name and you should be okay
Apr 12, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I need software for Maxtor (160 gb) onetouch 4 mini OS X 11.4
Maxtor is now part of Seagate, so your first step should be http://www.seagate.com
Dec 09, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Install driver of maxtor 160gb onetouch 4 mini
Hmmm What software do you need?
You should not need software to run the HDD. Just plug it in.
You can get the One Touch software from Seagate (who no own Maxtor) See
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
HTH
Dec 08, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Hay i am having Maxtor OneTouch 4 Mini (160GB).it does not detected by any computer except where its software is installed.plz ans immed
I've had this problem before (something similar) you'll need additional software from Maxtor.com so you're PC will recognize the new drive.
Jul 18, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Broke external hard drive
It depends on how badly bent it is. If you're stable with your hands, and can use a small nail to pry the deformed peice straight, do so carefully. If however you absolutely need to save the data on the drive and can't afford to have the bent peice fully break off, take it to your local computer repair store and they should be able to replace the connection.
May 05, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive Logo
207 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
