Question about Aiptek HyperPen 6000 Graphic Tablet
The f1 button on the pad is flashing and the pen and mouse no longer respond
Is it not responding because F1 on the pad is flashing? I have it on a compaq laptop and it WAS running perfectly before. I use it on my adobe photoshop..it is sometimes disconnected.
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
Mouse pad not moving the cursor
There will be a Fn combination for the mouse pad.Please have a look on the fn (F1 to F12) keys on top of the keyboard and you will find the mouse pad symble on any one.
Press that function key with fn key (usually with windows button) and the touch pad will start working.
Thanks.
Apr 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
Hi.
Regards.
Mar 02, 2010 | Ovens
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Please help installing my mouse and key pad!
Install all drivers for the mouse and after that you should just press the button for reset on your mouse and it should work
Jul 03, 2009 | Computers & Internet
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Mouse not responding.
I take it that you have a wireless mouse.
Myself I prefer the ones that plug into the console.
Jun 18, 2017 | Micro Innovations KB1045LSR Keyboard
F1 Error on Maytag Electric Oven
Found something on the net that said it may be a heat sensor so I returned my new touch pad ($220) and put in my old one that was giving me the F1error. I bought a heat sensor ($55) and crossed my fingers. It WORKED! F1 was no longer flashing and the oven's back up and running.. so much for the error codes.. F1 = touch pad and F4 was supposed to be the sensor..
If you're fixing it yourself and think it may be the touch pad, I recommend going through SEARS. Even though the touch pad was an electrical part they still allowed me to return it hassle free and most companies wont accept returns if it wasn't installed by one of their service professionals. So I was more than happy to get the $220 back when it turned out to be the heat sensor. Only downfall is that I had to wait 2 weeks to get the part. Hope this helps anyone with the same error.
Nov 14, 2008 | Maytag Kitchen Ranges
Keypad locked out
Consult your owners manuel for turning off the sabbath mode feature.
try to remember the whole f1 code. if it was f1-1 it could be a temperature problem
if it is f1-4 is could be a shorted keypad
the control pad could be locked out as well. try holding the cancel key for 3-5 sec to see if it unlocks the control
Feb 03, 2008 | Maytag MGR5751AD Gas Kitchen Range
Error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
Aiptek HyperPen 6000 Graphic Tablet Logo
73 people viewed this question
Top Aiptek Computers & Internet Experts
David
David
Willem.
Willem.
Gareth Cockram
Gareth Cockram
Are you an Aiptek Computer and Internet Expert? Answer questions, earn points and help others
