Question about Flotec Simer/Flotec/Omni 2105 Swimming Pool Cover Pump
Where can I buy a new flotec fpos 400x swimming pool cover pump
    Top Expert:
  • Flotec Master
  • 5,062 Answers
Amazon
Posted on Sep 20, 2017
2 Suggested Answers
  • 72 Answers
SOURCE: where can i order a part for fpos 400x the piece
If the fitting is a standard size, you could try repairing it with some plumbing fittings and pipe dope. Good luck!
Posted on Nov 15, 2010
Swimming pool pumps
No problem listed. Please repost with an actual question.
Sep 25, 2012 | Flotec FP0S1790PCA Utility Pump for Pool...
I purchased and installed this model pump (FPOS1790PCA). The first couple of times there was water on the pool cover, the pump seemed to work fine. I have several inches of rain water on the cover...
You may want to check with Flotec first since many of the manufacturers handle warranty claims directly instead of the store being involved. If the unit falls within the stores return period then just take it back and excahange/return it...if not, Flotec is at: http://www.flotecpump.com/ResidentialContactUs_ContactUs.aspx
Select warranty from the drop down menu and go from there.
John
Apr 19, 2011 | Flotec 2115 Swimming Pool Cover Pump...
Where can i order a part for fpos 400x the piece that you attach the hose to at top of pump snapped off
Nov 15, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
I have a Flotech FPOS1790PCA Pool pump that will run for 15 seconds and then shut off...how do I get it to stay running?
I have the same model and found that it frequently shuts off when it gets too much pine needles clogging the strainer.
I have unscrew the bottom "skirt" almost once a month and clean it out.
Nov 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump keeps turning off
this pump needs about 21/4" of water to operate properly, this pump will not remove all the water from the cover and will cycle on and off as it looses prime. If the motor turns completely off, it may be a an issue with low line voltage. you can try using a lager gauge extension cord to try and fix it, otherwise have an electrician test the line voltage.
Here is a pdf of the manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000049529.pdf
Sep 16, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pool pump not working
there would not be a fuse if this has a reset button I would suggest you return to company you got it from and have them replace the defected one thank you
please rate me
Apr 19, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Flotec Simer/Flotec/Omni 2105 Swimming Pool Cover Pump Logo
257 people viewed this question
Top Flotec Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Flotec Pool and Spa Expert? Answer questions, earn points and help others
