Question about Teac Audio Players & Recorders
I put my TEAC CR-H100 away about two years ago when re-decorating the kitchen - it was working fine. When I came to re-connect it recently the CD tray just wouldn't open. There isn't even any sound of a relay or motor trying to open it. the system has been stored in a warm dry place on top of a wardrobe. Any ideas?
    Genius:
  • 1,239 Answers
Hi
CD drives have rubber belts and wheels - if it used for a long time and you told that the system has been stored in a warm dry place on top of a wardrobe , perhaps these are worn out. A new CD belt will fix the problem.....
Posted on Jan 05, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 05, 2009
    here is another solution their is an tiny hole in the cd tray.. f their is... u insert a pin that cn fit to it you estimate the pin head is... while pushing the eject button. or you want to open your cd-drive without the button on the drive you could try this:
    get a peperclip make sure it's a straight line.
    then somewhere on the drive you will see a tiny hole just alrge enough for you paperclip to pass through.
    then you just have to puss a little and voila it opens.
  • ABHISHEK.C
    In order to close it I followed these steps:
    1. Remove drive and then cover (this will usually make the warrenty void)
    2. check that all the gears are not jammed (you may be able to move the tray a little and see the gears turn.
    3. If you look to the left on the underside of the tray there should be two flanges that snake in parallel with the front of the drive near the end of the tray. Now look into the drive to the left and under the tray and look for a lever connected to the component that moves the disc motor and laser up into position. This lever should run inbetween the flanges on the tray.
    4. If this is the case then you have to remove the tray from the drive. (mine had two teath stopping it but they can be pushed back with a screw driver)
    5. move the lever into position so when you slide the tray back in it goes in the slot on the tray.
    6. Assemble the case and test the drive!
    Notes: you may have to remove the plate with the disc motor on to get the tray out or force the tray out while holding the plate down. The gears don't need to be aligned and the band to the tray motor doesn't need to be taken off.
    Genius:
  • 1,550 Answers
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the cd.
The rubber thread which should be connected to the motor inside the cd player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Singer curvy
there could be something wrong with the cam that does the decorative stitches, you may want to have the machine checked..
May 27, 2013 | Sewing Machines
I have a TEAC AH300 stack with tape deck, cd, etc.. It's about 13 years old work perfect. Can I connect to iPod an listen to music through the TEAC?
If it has aux or audio input then yes, you will still need the docking station to the type of inputs that are available on the Teac. It should all be line level.
Apr 10, 2013 | Audio Players & Recorders
Teac CR H100 CD player just clicks when I press play and if it plays, it stops very soon. Is this teminal
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Sep 23, 2010 | Teac Audio Players & Recorders
I have a Teac D250 CD recorder it used to use TDK XA80 CD-R discs these are off the market and no other disc seems to work . It displays D-Unclock when I try . Is there a code to unlock this so that I can...
You have to look for input selection and make sure whatever way your recording from is connected. If you doing digital to digital, make sure the optical line is connected and the other is powered on. if it's analog or input or other also the same. I think it needs to recognize the other device. This is info from my teac rw d200. I love this and also use these disc's and maybe they would work on yours. The CD's MUST be made for Audio Burners and I recommend these two kinds...The label below MUST be printed on the CD's in order to work.
8_31_2012_5_05_37_am.jpg8_31_2012_5_06_16_am.jpg8_31_2012_5_06_28_am.jpg8_31_2012_5_22_59_am.jpgthese RW and all purpose are whatever you can find online. The RW just became discontinued. I bought some 2 years ago.
Jun 10, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
CD tray won't open
hi Dahanbury.
have a look on the front of the tray and see if you can see a very small hole.
insert the end of a straightened paper clip into the manual eject hole on the front of the drive,do not push it to hard just enough to see if it will open.
or go to this link and read up some more on this.
Use This Simple Trick to Open Your Stuck Disc Drive
if none of this is of any help to you,you may have to open it up and try and sort it from there.
Dec 14, 2017 | Audio Players & Recorders
CR-H100 CD/Tuner/ Amplifier. New about 5 years ago. Tuner won't retain presets. Despite following manual's instructions on both auto and manual tuning, the preferred programme settings are almost always...
These resceivers have a bulit-in device to retain some electricity to feed backup memory. It can be a battery or a capacitor and I think they have reached their time to be replaced.
Nov 21, 2008 | Teac Audio Players & Recorders
Recording from audio tape to laptop
Hi Vincent.
Just use the play out connections on the back ot the deck, and connect them straight to the line in socket on the lappy. Use a RCA stereo to 3.5mm stereo jack connection, levels will be fine. Try audacity as a decent freeware recording program. Woks well, and you can use half decent plugins to tweak the audio. :)
regards
robotek
Jul 05, 2008 | Audio Players & Recorders
647 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
