Question about Mitsubishi Televison & Video
Resetting eeprom How to reset eeprom on ws 55809
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
These sets including this one have 3 hidden menus---OPTION menu which allows a hard reset of everything except the convergence, Adjustment menu--be careful in there, and Convergence menu which adjusts better than customer one and saves better.
Each is accessed with a four number code using the Mitsubishi remote.
I have a list of most of the codes available.
Posted on Nov 07, 2012
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi ws-55809 needs new red tube
you can get a red mitsubishi tube at the following link and it comes with free shipping. If youre not sure which one to order, leave them a email and they will respond quickly, just let them know your model number and what youre needing. they are listed under the projection CRT catagory on the left side of their page. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jun 22, 2008
tatunka
  • 85 Answers
SOURCE: Mitsubishi WS-55809 won't turn on
find your reset button
Posted on Nov 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: I have a mitsubishi ws-55809 power comes on and then goes off
try to check it again as these are the only codes for your model.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occurred.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
Posted on Mar 29, 2009
SOURCE: red convergence on my ws-55809 is off
The lense adjustment won't help. There are two convergience chips inside, each has 16 pins. If you take the big tray, with all the boards, out and turn it over, you will see that one of the chips has a pin that goes to a contact labeled, "RH." You can't miss the chips, they are stuck to a huge, finned heat sink, about 4'' x 7". Check the continuity from that pin to it's contact with an ohm meter. You may get lucky and get by with simply a re-solder or jump on that pin. Those convergience chips are like computer processors, are subject to extreme heat, depend very heavily on their heat sinks and cooling fins and could easily get hot enough to break a solder connection. Like computer processors, they should have been designed with fans as well as heat sinks. Don't kill yourself. Even unplugged, a tv has enough stored energy to be fatal.
Posted on Aug 22, 2010
Tv won't power on. WS-55511. Diagnostic is 1 blink then 2 blinks.
The Tv needs to have a system reset that is what the blinking light means. here is how to do.
Use the System Reset button. If this happens frequently, obtain an AC line in power conditioner / surge protector.
Dec 11, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi WS-55809 justs has a blue screen. I think I may have accidentally changes something to 1080i. Hos can I reset it?
Your televison might be stuck in Home Theater Mode.
If so can you pull up the menu.
Please post back so I can help you further.
asnowman
Oct 11, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a Mitsubishi ws 55909 and all of a sudden the convergence will not line up. The red lines have a wave pattern that will not reset. Any ideas?
You will need to replace the convergence amplifer chips and any related blown resistors, and perhaps two fuses.
Search this site for convergence fixes.
Sep 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I need master reset code for v-lock ws 65"
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jan 23, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
