Question about HP DeskJet 810c InkJet Printer
I have hp 810c printer
I have black ink cartrage installed but i dont have colour cartrage,so i want to know is there any way i can print only balck without installing colour ink cartage.
    President:
  • 2,692 Answers
No.Not according the HP.
Posted on Jan 05, 2009
Kodak 5300 printer: I just changed the black ink but it is printing as though there is no black ink. Ihave tries calabrating, cleaning, deep cleaning, etc. It says there is a full cartridge of ink.
From what i understand with the kyocera colour printers theres a menu option to print black as black opposed to a combination of the colours. I'm not too sure where it is, however it sounds like the kodak is very simular and is using the colours to create black instead of using the blank ink cartrage.
Jun 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink cartidges are all installed and registering ok. New balck ink installed but will only print in colour and not black print what can I do as I need docs printed urgently?
Does it take (pull up the paper) in the paper? If so, Try to print only images and check if it works or not. It'll be much easier if you let us know the program from which you are printing. Also try to print only in text using Ms Word, wordpad or notepad. If possible update your driver. Good luck.
May 26, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Black ink not working
Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
Oct 07, 2009 | HP Photosmart C7180 All-In-One InkJet...
When i print a page black ink text thin blue lines appear also a blue ink blob
Method 1:Remove your colour cartridge wen you require only balck ink[The blue lines are often signs of empty cartridge]
Method 2: while printing select 'Use Black Ink Only'
Oct 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
WONT COME OUT OF THE ALIGN CARTRAGE MODE
if the colour cartridge is empty or any of the three colour is not got printed on the allighnment page it will not comple allignment.replace the colour also or get you colour cartridge refilled.
May 06, 2009 | HP PSC 750 All-In-One InkJet Printer
Have replaced black ink twice, cartridge still will not align, test page prints every colour fine except black comes out pale green
Well I dont know if this will fix your problem but it worked for me.
I removed my ink cartrage put it in a printer exact same modle and put it back in.
Printed with out an issue. however the only problem is you need 2 printers. :( have a friend that may have the same one?
May 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
Lexmark x1190 no black ink comeing out
you may need to reinstall the cartridge once again and test
Sep 27, 2008 | Epson Stylus 880 InkJet Color Printer
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
HP DeskJet 810c InkJet Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
