Please locate the dimmer module.
I attached a picture below.
Carefully turn the round knob from left to right.
Move the knob from the extreme left to right few times.
Check the operation of the trunk opener,gas door open and timer delay to rule out a disconnected cable (common cable or ground)
A good dimmer should operate smoothly on its entire range.
I recommend you to pass a vacuum cleaner around the dial to remove any dust and dirt.
Be sure to check all fuse and corrosion around the fuse holder.
If all else fail then the GM part number for your dimmer module is
10008706 K4.
If you shop around you can get a used dimmer for under $30.
