Question about Fisher and Paykel Washing Machines
I have a Fisher & Paykel smartdrive 501 washing machine,the machine stops on the rinse cycle & it try's to spin but stops and beeps. I have put it into diagnostic mode & this is the co
I have a Fisher & Paykel smartdrive 501 washing machine,the machine stops on the rinse cycle & it try's to spin but stops and beeps. I have put it into diagnostic mode & this is the code that comes up. OOIOIOII. Any answers would be great thanx.
  • Anonymous Mar 19, 2014
    machine will not spin and beeps before it goes into rinse and spin mode
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 66 Answers
This is copied from service manual:
43. (00101011) Phase 1 to 5 - Out Of Balance Switch Fault
The Motor Controller has found that the signal returning from the out of balance switch indicates that the switch is permanently ON or the harness to it is disconnected.
Primary Source - Mechanical
Action
1. Check Smartdrive is level and that the bowl is not contacting the out of balance lever.
2. Check that the bias spring is correctly located between the wrapper and the outer bowl.
3. Check that the out of balance switch is free to move. Check switch operates correctly when
activated. Replace switch if suspect. If the out of balance switch shows signs of corrosion
replace the switch. Check the harness to the switch is connected correctly. If the harness
terminals show signs of corrosion, then fit a new harness.
4. Check the suspension is not catching.
Secondary Source - Motor Controller. (Display Module Phase 1).
Action - Replace Motor Controller. (Display Module Phase 1).
Posted on Jul 03, 2013
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
Take a look at this document.
Posted on Nov 07, 2012
Krazytech
  • 725 Answers
SOURCE: my fisher and paykel smartdrive
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Posted on Dec 15, 2008
  • 3 Answers
SOURCE: fisher & paykel smartdrive MW095AU wont spin
Does the pump empty the machine, if not you may have a faulty pump, these have no protection againt water coming from above and regularly fail
Posted on Feb 09, 2009
  • 17 Answers
SOURCE: fisher paykel smartdrive 601
Most likely a blocked pump
Posted on Apr 19, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
It was on the last cycle spin it stopped had pumped the water out but stopped spinning.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/us/support/expert-tips/Fisher & PaykelFind Tips, Troubleshooting Information, How-tos, FAQs and Answers to Commonly Asked Questions about Fisher & Paykel Appliances.
also on Youtube
Aug 17, 2015 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Stops half way through rinse cycle and beeps
Best off to call a certified repair company such as Sears.
Mar 20, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher n Paykel Smartdrive 9
Most waashers rinse with cold water and if your cold water screen on the valve is plugged and it can't let water in it may cause your problem.
Aug 30, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
497 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
