Question about Q-Tec 100 USB Web Cam
I can not find a driver should I have lost my cd
  • 3,606 Answers
Hello you can download the driver here:
http://www.qtec.info/service/support/drivers.htm.1657.html
But windows vista and windows 7 is not supportet.
Good luck
Posted on Nov 07, 2012
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT
Sep 21, 2012 | Numark Industries Numark 5000FX 5 Channel...
Dear sir, can tell mwe where can I down load the driver for vf0330 we cam pls since I lo st the cd during shifiting.pls tell me the correct driver
hi,
pls tell me what kind of OS " xp - vista- win7 (32 or 64 bit in each one of OS) " you are using on your pc now ?
dose your web cam is creative mark ?
after you answer me above mentioed two question , i will be able to intoduce you
the correct driver.
god luck
gorbesia
Jun 15, 2011 | Cameras
I have lo.st my frontech installer driver for model no jil 2222 plz help
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jul 07, 2010 | Mri WebCam
HL-DT-ST CD ROM GCR 8523B
that lg dvd doesnot need any driver to be downloaded, drivers for it are provided with windows system
Nov 21, 2009 | LG GCR 8523B Internal 52x CD-ROM Drive
Cd/dvd is not working on my acer aspire 5610
I encountered the same problem for HL-DT-ST DVDRAM_GSA-T20N ATA Device using Windows Vista and after updating to SP1. For detailed solution, refer to this link: http://howtoresolve.blogspot.com/search/label/HL-DT-ST%20DVDRAM_GSA-T20N%20ATA%20Device
Feb 26, 2009 | Acer Aspire 5610-4648 Notebook
No tengo el driver de mi cd-rom/dvd y este no funciona
Lo mejor que puede hacer es dirigirse al website del fabricante e instalar el driver más actualizado
Sep 13, 2008 | Computers & Internet
My razr motorola v3 will not connect to my computer.i have downloaded the 64 bit drivers but windows still does not recognise my phone.ty ya tengo instalado el programa de ma movil em mi pc pero no lo...
Desinstala cualquier software que hayas instalado para el teléfono móvil e Instala el Mobile Phone Tools. Luego sigue las instrucciones del asistente para conexión.
May 03, 2008 | Motorola Mobility RAZR V3
HL-DT-ST DVD-RW GWA-4082N
my HL-DT-ST DVD-RW GWA-4082N has a problem i cant up date the drivers in my computer it is missing so if in incert a cd it cant be found my HL-DT-ST DVD-RW GWA-4082N has a yellow exclamation an status Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Feb 29, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Aug 01, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Q-Tec 100 USB Web Cam Logo
Top Q-Tec Computers & Internet Experts
David Payne
David Payne
Are you a Q-Tec Computer and Internet Expert? Answer questions, earn points and help others
