Question about Samsung SyncMaster P2370 23" Monitor
Is it some kind of virus or what? Does it for about 2 weeks. I fragmented and check computer for viruses but all negative. I use also SpeedMyPC but no help. Thanks for help Carlo
  • Lorak Ylesev Nov 07, 2012
    I unpluged cables and repluged again to be sure that there is no oxidation on contacts I will obsereve if it helped and tell you later. Thank you for your kind help, Hermes
    Genius:
  • Samsung Master
  • 2,432 Answers
You will need to hooked up first with other monitor just to ensure if the cause is only with in the monitor. after you replaced with other monitor then the same issue so that was mean the problem is the pc. you can scan disk the hard ware to the other pc , usually it was happened if not properly shut off.
Posted on Nov 08, 2012
4 Suggested Answers
  • 17 Answers
SOURCE: I'm trying to help a
the graphics card could be burned out.
test the computer with a different monitor
if the same thing happens it ts one of 2 thinga; dead graphics card or virus
Posted on Jul 20, 2009
budmrtn
  • 11361 Answers
SOURCE: samsung gh19ws (920nw) model lcd
Common problem is in the DC filter caps in the power supply circuits, that will be the first thing to look for first, please note that bad cap can look normal but can have high ESR.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 23, 2010
  • 452 Answers
SOURCE: Suddenly all colors are washed out and everything
it can be a problem of VGA cable try to move it if the same problem check the degauss circuit the posistor and relay and the transistor
Posted on Oct 16, 2010
Dell computer hangs
you have problems with windows, check registry errors, download any portable antivirus and check on viruses
Dec 17, 2013 | EliteGroup K7VMM Motherboard
Tip
Protect your COMPUTER by VIRUS
How to protect your computer by Virus?
Few tips.
1. Try to updated your anti- virus always.
2. Use original anti-virus support.
3. Minimum try full system scan 3 days a week.
4. Before open any external memory device ( Example : hard drive,pendrive, memory card, mobile, etc ) don't forget to scan.
5. Symbol of virus infected device is Auto Run option. ** if you use a pen-drive then just right click on drive, if your seen the top option is Auto Run / there is 2 time showing Auto Run that's mean the device infected by virus."
6. If you think the system not going fast then before just run scan only SYSTEM 32 folder which is located inside C: drive> windows> system32.
7. Weekly once clean your temp internet files, recent use document etc.
Thanks .
Regards,
Rajdeep.
on Jan 30, 2010 | Computers & Internet
Good Day! I would like to ask for your help about problems regarding to my Toshiba Satellite 1801. My laptop is very slow, refreshing it takes almost 5 minutes and Opening a programs takes almost 15...
Welcome to FixYa!
here are some steps that you may follow .
1. go to start > run> type MSCONFIG
a window shall open and DISABLE all the items that are being run at START UP
here are caps
See if that helps you ?
More over have you tried installing a Anti-virus.Cause sometimes Virus make the computer slow.
, as a tip De-fragment your hard drives time to time.if virus has hit your computer try installing a fresh copy of windows and then installing Anti-virus .let me remind you when you install a copy of windows do not attempt to open any drive cause there are auto-run viruses. so you first clean your computer then go to other drives clean and safe.
Do comment if it helped you in ANY MANNER !
Apr 13, 2011 | Toshiba Computers & Internet
My computer has a lot of virus n run slow n need 2 be fix
To start with you need to get Lavasoft Adaware installed on your computer. It is free to download and install.
When you have it installed, run it about 3 times rebooting your computer after each run. This should take care of most of your virus problems. After that I would suggest getting a free antivirus software. I use AVG anti-virus. Works very well.
Apr 12, 2011 | Acer Computers & Internet
My lifebook p2050 keeps gettng slower and slower. Why and is there a solution. Thanksin advance.
Solution
1. You must have the laptop or notebook cooling pad placed under your laptop or notebook. Cooling pad will help the notebook or laptop cool and stable while using in a long period of time. Cooling pad also can avoid burning the motherboard from overheating.
2. Scan for viruses and you must have the latest or updated anti-virus to make it sure that your security can handle the annoying viruses and worms.
3. De fragmenting your computer can make it faster, at least every 30 days.
4. Formatting your computer can make faster accessing, loading and even browsing on the Internet.
Have a nice day
Feb 22, 2011 | Fujitsu Siemens LifeBook P5020 Notebook
My computer is slow. I have a Compac Presario PC. I think I have some viruses. What can I do?
You can do all or one of the following: 1. De fragment the hard drive. 2. Upgrade the RAM. 3. Do a factory restore - this will totally remove the virus, but you need to backup all your important files before performing. 4. The least recommendation - remove or uninstall unnecessary programs.
Nov 12, 2010 | Compaq Presario SR5710Y PC Desktop
Will not load games
First of all get a good Antivirus software and scan your PC thoroughly after UPDATING it. Updating the Virus software is extremely important.
Secondly after doing the above step install a Registry cleaning software. I recommend Uniblue Registry booster or Regcure. Virus and unclean registry are number 1 reasons to PC slow down.
Check your hard disk if it is near to full. Use the Windows built in disk cleaning software to clean unnecessary files. After that De-fragmenting the disk will also help a lot. To de-fragment a disk Go to accessories in the start menu and then go to system tools. Find disk de-fragmentation and run it the PC performance will dramatically enhance but Virus and registry cleaning is recommended to be done first.
Jul 26, 2010 | HP Computers & Internet
I have virus in my computer,,,,in each folder there is one more folder which is empty,,,made by it own sellf
Yep a virus, you can either get antivirus or my suggestion is to back up music/pictures and essentially take the computer back to factory with a factory install disc.
Those are best options
Mar 12, 2010 | Toshiba Satellite Pro L300 Notebook
Pc running slow
If a machine is running slow, there is usually 3 reasons...
1) Remove all spyware using a program
2) Run an anti-virus like AVG Free Anti-Virus to clear any viruses
3) Add some memory to the machine
May 07, 2008 | Computers & Internet
Anti virus
You of course can run multiple instances of anti-virus programs in your computer assuming that the anti-virus will allow competition in the resources. However. more often, this would only eat on your memory and processor so it is not advisable and there is no significant gain if using 2 or more anti virus bot several downside.
How to check what anti-virus is running, there are several ways:
1. Go Start, All Programs and check what anti virus has been installed;
2. Go to Control Panel, Add/Remove Program, the programs installed would be listed including your anti-virus;
3. Go to Start, Run, type "msconfig". next window go to Startup tab, it will show what programs are running upon Windows start up including your anti-virus.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 24, 2008 | Microsoft Windows Vista Ultimate Edition
Samsung SyncMaster P2370 23" Monitor Logo
37 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
