Question about Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug
Heat fan motor debris - Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug
    Master:
  • 689 Answers
Take it out .End clean Debie OutLOL:
Posted on Nov 09, 2012
Heat fan noise too laud. How to fix it
you have to access fan at heater core under dash and either clean debris //lube bearings or if beyond lube replace fan motor
Jul 08, 2016 | Toyota Camry Cars & Trucks
Fan making clanking noise like it is hitting something the part seems to be located in the lower left front passenger side
sounds like blower motor fan for heat, the motor itself can be going bad or something is hitting fan blade inside heater box, I have seen all different things in heater boxes including acorns , leaves and general debris causing noises when fan for heater runs, you need to take it apart and check for anything that might be hitting fan if not motor is going bad and needs replacement, good luck.
Apr 04, 2015 | 2005 Dodge Caravan
How to fine defrost noise when turning heat on
This can be many things, but most common is debris in the heater fan motor area. Hard to fix without removing fan motor and blowing out heater ducts, but sometimes compressed air blown through ducts can clear it out.
Feb 22, 2015 | Cars & Trucks
Corsa 2003 fan noisy and not blowing properly any ideas
If this is the blower motor for your inside ac/heat then it is most likely the bearings within the motor that are worn out and causing this noise. This would reduce air flow as well. There is also a slight possibility that there are particles of debris trapped in the cage and causing it to make noise and reducing its function. But I would say most likely it is the bearings and the motor needs replaced.
MJ
Aug 08, 2014 | Cars & Trucks
Makes a noise when turned on.. sounds like fan or fan motor.
I would make sure the heater is unplugged then remove backscreen and foam filter. Carefully clean firter with warm water and alittle dish soap. Rinse thouroughly and air dry it. I would clean any hair lint or other debris from fan blades,motor and heating elements. You can use a tooth brush to clean heating elements.You can also use a drop or two of light grade machine oil or WD-40 on blower shaft where it enters the motor. Wipe off any excess oil and when you're sure filter is dry reassemble and try it. Hope this helps you.Thanks
Nov 16, 2010 | Pelonis Disc Furnace Heater
2003 trailblazer I have no heat or air coming out of my dash vents
Is it no heat/air when sitting still, or no heat air period? If the heat and air blow slightly when driving you have a bad blower mower/resisitor and its not allowing the air to blow into the cab. If not blowing period when moving probably bad heater controls or fuse... Worst case scanario is you have an electrical problem that needs to be diagnosed
Jul 15, 2010 | 2003 Chevrolet TrailBlazer
There is a noise that my heater makes when the heat is on. The heat still works, but as you turn it up higher , the noise gets louder. What could be causing this?
Probably some leaves or debris in fan cage. remove fan and clean. or it could be a bad fan motor bearing remove and replace.
Apr 20, 2010 | 2001 Jeep Grand Cherokee
Why does theDashboard vibrates when the heat is
The fan motor is close to the dash and thats coming from the fan motor....prob. the worst when on high...??
Dec 20, 2009 | 1999 Pontiac Grand Prix
When you turn the heat on the blower motor starts making a grinding noise
could have debris in the fan housing or the blower motor bushings or bearings are going out. take the fan out of the air conditioning case and vacuum out the air conditioning/heater core assembly case. then hook everything back up and see if this works.
Oct 12, 2009 | 2000 Chevrolet Silverado 1500
How to take apart case and back flush heat exchange fins
You do not have to remove the coils. Just carefully lift the top with the motor and set it aside (power off). Spray the outside with a foaming cleaner (Dow bathroom) and flush from inside out.
May 24, 2009 | Weather King 12AJA4801AH Air Conditioner
Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Logo
Top Buck Car Audio & Video Experts
xxxxxx xxx
handygirl911
handygirl911
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
