Elonex lt37f3v1 tv - Computers & Internet
  • 416 Answers
And?
Posted on Nov 15, 2012
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
All in one tv code
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 07, 2015 | Elonex LT37F3V1 37 in. LCD TV
MY TV STOPPED SHOWING PICTURES BUT THE SOUND IS OK
Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Jun 03, 2014 | Elonex LT37F3V1 37 in. LCD TV
How do i fix my elonex tv
switch off.wait for 5 mins.
press & hold power button till it turns on then off.
ifno luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
May 04, 2014 | Televison & Video
Elonex tv remote code
0382, 0328,0326. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Try this link too.
http://electro-medical.blogspot.com/
Mar 10, 2014 | Philips Televison & Video
How do i remove the capacitors from the tv
You should have all the tools to do this work. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Sep 18, 2013 | Elonex LT37F3V1 37 in. LCD TV
Elonex lt37f3v1 powers off then wont power on
all this points to something that involves the set's microprocessor =standby flashing, will not respond to controls= this could be a issue in the standby/main power supply or elsewhere but I would look there first.
I am not sure of age of this set but:
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.
Mar 29, 2012 | Elonex LT37F3V1 37 in. LCD TV
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
