Question about Brother MFC-9840CDW Laser Printer
Won't detect black cartridge
  • renee martin Nov 07, 2012
    This is a laser printer not inkjet. I don't see electrical contacts and there are no print head nozzles. Any idea if there may be a sensor that needs to be cleaned so the toner cartridge can be detected? This error came up after I replaced the yellow cartridge and cleaned the corona wires.
  • Chas Peters Nov 17, 2012
    I have the same problem,, First the cyan cartirage ten out and I replaced with a re-manfacturered one no problem, carts have a security sticker on the side, after a week it asked for black so I replaced the black as usual, but have tried 2 of them now and still says, "Black toner needs to be replaced" Next will have to open to see if gear is reset or the optical sensor needs to be covered, much like when doing a refill yourself.
  • 25 Answers
I have the same problem, first magenta said it needed to be replaced, then a couple of weeks later it asked for Black, I replaced the black the same way, and then also tried another new cartridge (both Re-manufactured) they have a security sticker on the side. Both didn't work so next I will try opening the side to see if the gear is reset or the optical sensor needs to be covered as when you add toner to an OEM cart. Strange that only the black seems to cause problems. The cost of toner and ink (for ink jets) is so cheap, yet if you figure it out by weight it costs much more than gold. Sometimes its just easier and more cost effictive to buy a new printer
Posted on Nov 17, 2012
    I have the same problem, first magenta said it needed to be replaced, then a couple of weeks later it asked for Black, I replaced the black the same way, and then also tried another new cartridge (both Re-manufactured) they have a security sticker on the side. Both didn't work so next I will try opening the side to see if the gear is reset or the optical sensor needs to be covered as when you add toner to an OEM cart. Strange that only the black seems to cause problems. The cost of toner and ink (for ink jets) is so cheap, yet if you figure it out by weight it costs much more than gold. Sometimes its just easier and more cost effective to buy a new printer
  • 826 Answers
->First check the cartridge compatibility.
->Are you sure not to touch the electrical contacts or print head nozzles when handling the printer cartridge.
->To clean the print head
->Update the printer driver if it is necessary..
If you need any kind of technical assistance on printer you can contact support cell at http://www.vtechsquad.com/
Posted on Nov 07, 2012
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
I have replaced the black ink cartridge in my Kodak ESP5210, I only need to print in black, now the colour has run out which I don't need (the original cartridge). I have tried taking out the colour...
go to printer & fax right click on the printer then select maintenance look for the cartridges in (default both cartridges will be detected) you must select only black then close it then try to print
Aug 03, 2011 | Office Equipment & Supplies
Deskjet troubleshoot My HPdeskjet 5550 won't print.: My HPdeskjet 5550 won't print. The orange light is flashing
hi..........
In this error condition, the following light pattern displays on the product control panel and a message might display on the computer:
  • Print Cartridge status light : On
  • Resume light : Off
  • Power light : On
Figure 69: The Power light is on and the Print Cartridge light blinksc02645167.gif
    hpweb_1-2_minus.gif Causes
    • The cover on the product might be open.
    • There might be a problem with one or both cartridges.
hpweb_1-2_minus.gif Solutions Follow these solutions in the order presented to resolve the issue. Solution one: Close the top cover on the printer
  1. If the cover on the product is open, close it.
  2. Press the Resume button (c01219285.bmp ) to continue printing.
Solution two: Determine the cartridge issue When there is an issue with a cartridge, a yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is. Follow these steps to determine the cartridge issue, and then continue to the next section for solutions to resolve the issue.
  1. Open the top cover on the product. Wait for the carriage to move. The yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is.
  2. Look at the drawing and then find the icon in the following figure that matches the drawing. Each of these icons represents a different cartridge issue. Use the icons to determine the cartridge issue. Figure 70: Determine the cartridge issuec02645168.gif 1 - Tri-color Cartridge Problem icon 2 - Black Cartridge Problem icon 3 - Tri-color Cartridge Low-ink icon 4 - Black Cartridge Low-ink icon 5 - Cartridges OK icon
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP DeskJet 5550 InkJet Printer
I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Jul 11, 2011 | Dell Office Equipment & Supplies
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Brother MFC-9840CDW Laser Printer Logo
51 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
