Question about Vector 20 Million Power Series Spotlight
Replacement batterys for Vec 027 safety start battery booster instruction
4 Suggested Answers
  • 15 Answers
SOURCE: Where can i find a replacement battery for my VEC
Vector was acquired by Black & Decker in 2006, and their old website just sends you to the B&D site. I have had no luck finding a replacement battery.
However, Amazon.com still carries the original Vector 1-mil spotlight.
Posted on Jan 09, 2010
  • 973 Answers
SOURCE: Replacement battery for the Vec 192 spotlight and
You can order one from Black and Decker, they purchased Vector in 2006 and service all their products, here is the link to order; http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
CarlGlas
  • 283 Answers
SOURCE: My Vector model #VEC117FS has a battery that is
There are many companies on the Internet that offer Sealed Lead Acid Batteries, which may be less expensive than replacing the light. I would suggest identifying the particular battery your light has and then check what's available on the Internet to make a decision on whether it is cheaper to replace the battery or the light.
http://www.batterywholesale.com/battery-store/SLA-batteries
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
http://www.atbatt.com/sealed-lead-acid-batteries.asp
http://www.zbattery.com/Batteries/Sealed-Lead-Acid
http://www.planetbattery.com/product.asp?id=10
Posted on Nov 13, 2010
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
I JUST REPLACED THE BRAKE BOOSTER BOTH FRONT BRAKE LINES AND EVERYTHING WENT SMOOTH, NO ISSUE AT ALL. HOWEVER, AFTER SOME TIME DURING THE REMOVAL AND INSTALL OF THE BOOSTER THE BRAKES WHERE ON AND I DIDN'T...
Welcome to FixYa.com
Does the Radio work or is it asking for a code?
Thank you for Using FixYa.com
Kind Regards,
Your Master Technician Adviser, Lee
Jan 30, 2011 | 1993 Chevrolet K1500
I have not been able to find a store who handles the vec 142 in our area I have questions like battery battery life and how much are replacement batteries if available what is life of bulbs and how are...
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Nov 01, 2010 | Vector VEC 142 Rechargeable High Intensity...
I forgot to turn off the lights in my car. What can I do to start the car running? Do I need to replace the battery?
You can either jump the battery, or remove the battery from the car and bring it to your local repair shop to have it charged and tested, (a lot of auto supply stores will do this for free so call around), or you can jump start your battery and hope it holds a charge.
To jump a battery you will need a set of jumper cables and a second car, or a battery booster pack, (nice investment, they really are handy in a jam).
To jump a car with jumper cables:
******* Always where eye protection*********
1) Open the hood on the dead car and locate the battery.
2) Park the second car as close to the front of the dead car as possible, (just try to leave enough room to walk around the vehicles if you can).
3) Open the hood on the second car and locate the battery.
4) Attach the red, (positive) cable clamp to the Positive, (+) terminal of the battery on both cars.
5) Connect the black, (negative) cable clamp to the negative, (-) terminal of the battery of both vehicles.
6) With the second car running leave the vehicle to sit for about 5 minutes then attempt to start the dead vehicle.
7) If vehicle fails to start, wiggle the cable clamps to create a better connection.
8) If vehicle starts, remove the cable clamps negative first then the positive.
9) You may consider bringing the vehicle to your local auto supply to have the battery load tested once the car has run for a while, (most auto supply stores will do this for free so call around)
Using a booster pack is basically the same, except, you replace the second car with the booster pack. Follow the manufacturer’s instructions for charging the booster pack before use.
Good luck. Please rate, thanks.
Mar 07, 2010 | 2003 Toyota Corolla
How can i start the audi becuse the battery is dad
You could try to 'jump-start' with a booster cable.
Connect one end of the negative cable of the booster-battery to its negative terminal, and connect the other negative end of the booster-battery to the engine block (ground).
If booster battery is not maintenance free, you must take off their top caps.
Connect each ends of the positive booster-cable to the positive ends of each battery.
Start the car with good battery first, then start the Audi.
If the Audi fails to start after about 20-minutes, it means that its battery needs to be removed and charged with battery-charger, or a new one put in its place.
If the Audi has a standard transmission, you could have helpers push it, and apply the 2nd gear once it starts rolling.
The engine should fire up.
If it fails to fire up, have the dead battery replaced or re-charged.
Dec 05, 2009 | 2004 Audi A8
2000 plymouth neon wont start it was dying every five minutes so we parked it and replaced the safety neutrel switch got a new battery and bypassed the stater to the battery itself and it spins over but...
You may need to replace the cable end that joins the ground cable to the top starter bolt.Useing booster cables from the ground post of the battery to the engine block should confirm this.
Nov 07, 2009 | 2000 Plymouth Neon
I purchased a VEC142 worklight and cant get it to charge. This light is brand new. never been used. I returned the first one i purchased for the same reason. and i cant figure out why it wont work. I do...
The battery is dead, even new lead-acid batteries can be no good if they have been sitting for awhile, you can contact Black and Decker for Warranty or to purchase a new battery. Here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?r=No%20%Results
Jul 04, 2009 | Vector VEC 142 Rechargeable High Intensity...
Vector 20 Million Power Series Spotlight Logo
65 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
