Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fan motor stop running - GE (PSS26MSRSS) Side by Side Refrigerator
    Top Expert:
  • GE Master
  • 9,472 Answers
See other post.
Posted on Nov 07, 2012
New fan motor gets hot and stops after an hour have new computer
Sounds wired wrong, possibly wrong wires on capacitor.(if there is one of course) need to have wuring schematics and make sure its wired right. Hopefully its the right motor!!
Dec 22, 2016 | Heating & Cooling
My QL60 just stopped sucking. The motor and fan run fine.
If the fan is running there has to be suction. If there is none it is because the air in entering via some other port and bypassing the normal intake. Check it out. Check hoses and fittings.
Mar 05, 2016 | Vacuums
The blower fan has stopped working
Most often, blower fan motors gets corroded and or the ground wires gets corroded or loose. Try cleaning up the ground connection first and test. If it does not turn, you've got to test if the fan motors work by directly running a positive wire to the fan motor connection. If fan motor does not run, its dead.
I had experienced though that the fan motor was entangled with threads from the rags used to clean the car, these coupled with dirt and grease held the fan motor to a stop. A simple clean up did the trick.
Oct 02, 2014 | 1996 Kia Sportage
WHAT CAUSED MY CONDENSER FAN TO STOP RUNNING
If the refrigerator is running without any other problems, then just replace the fan motor. Here is the fan and it is only $36.80. No where near $100.00!
Oct 15, 2012 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Outdoor fan motor is not running fast enough?
Check to make sure that you have the correct voltage going to the motor. It sounds like you lost one of your legs of power which would give you 110v instead of 220v. Or it could be in the pc board.
Oct 15, 2008 | Hitachi RAS-09UH Air Conditioner
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Jul 22, 2008 | Heating & Cooling
GE (PSS26MSRSS) Side by Side Refrigerator Logo
13 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
