Question about Peltor MT53H7AWS2 Bluetooth Headset
Peltor MT53H7AWS2 Bluetooth Headset pairing instructions
    New Friend:
• Establish the Bluetooth link between the headset and another Bluetooth device by pressing the raise volume (+) and lower volume (-) buttons simultaneously for at least two seconds. Note that the headset must be switched off while you do this!
Some models of mobile phone require a pin
code in order for the mobile phone to identify the
headset. If this is required, enter four zeroes (0000).
This applies to all Peltor WS headsets and cannot be
changed by the user.
Posted on Apr 04, 2015
How to pair my sprint slx-800 to my android phone
You should search for this topic and answers, First.
Try 0000 that's the default for all bluetooth accessories.
If that doesn't work, here is generic instructions:
Paring a Bluetooth Handset with Android phone:
Instructions:
Now that you have your headset in pairing mode, proceed to pair it with your phone:
From the home screen, press the Menu key and then select Settings.
Tap the "Bluetooth" toggle to ON.
Tap Bluetooth to scan for devices.
NOTE: You will automatically be connected to an available saved device when Bluetooth is turned on.
Tap one to connect.
NOTE: A security code may be required. (Try 0000)
The Bluetooth connected icon will be displayed in the notification bar, and the device will now be labeled as Connected.
Place calls using the Bluetooth headset
Ensure the Bluetooth headset is paired with the handset.
Place the Bluetooth headset over your ear.
Dial the desired the phone number on your phone, and then tap Call.
Receive calls using the Bluetooth headset
Press the Call button on the Bluetooth headset when a call is received.
Aug 20, 2015 | Sprint Cell Phones
Tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 | Cell Phones
Tip
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
86707
86710
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
Pairing MT53HP3EWS2
The device you want to pair with these headphones must be using Bluetooth 1.3. The current version of Bluetooth is 2.x. Others have had difficulty pairing with Android or iOS devices.
If the device you are pairing with is a radio communications device, then you will require an adapter that mounts to the device.
Aug 12, 2014 | Peltor Radio Communications
How to put peltor bluetooth into pairing mode
Normally Peltor headsets work as follows:
1.) Turn the device off.
2.) Once off, hold the on/off/mode button for 5 seconds until you hear a voice say "pairing mode"
3.) Make sure bluetooth is active on your device and search for the Peltor headset, once you find it select it.
4.) When prompted for a pairing key use 0000
that is 4 zeros.
5.) Headset should say pairing complete.
As with moth bluetooth devices remember this muse bt done within a normal amount of time so have your device ready to search by time you put headset in pairing mode will help.
Dec 22, 2012 | Peltor MT53H7BWS2 Bluetooth Headset
How to operate
"First, turn on Bluetooth and Bluetooth visibility in your phone. This makes your phone visible to other Bluetooth devices.
Headset instructions:
  1. Make sure that the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
  2. Press and hold the On/Off button for at least five seconds, until you hear along high frequent beep and the light flashes red and green.
  3. The headset is now in pairing mode.
  4. If your phone supports auto pairing, press Yes when the question "Add device?" appears in your phone. If not, continue with the next step.
  5. Prepare your phone according to the phone instructions on how to add a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
Phone instructions (NB: these may differ a little depending on phone model. For exact instructions, see Pairing instructions for the specific headset and phone model on www.sonyericsson.com/support.):
  1. Enter the main menu and go to Settings, then select the Connectivity tab.
  2. Select Bluetooth > My devices.
  3. When New device appears, press ""Add"".
  4. The phone starts searching for devices. Make sure that the headset is in pairing mode.
  5. When the headset becomes visible in the Devices found menu, highlight it and press ""Select"".
  6. Enter the Passkey (0000 by default) and press ""OK"".
The headset is now added to the list of paired devices and is ready to use."
Mar 26, 2011 | Sony Ericsson HBH-IV840 Bluetooth Headset...
How to use bluetooth
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
What is the passcode for vh300 bluetooth sony ericsson?
Accessory instructions: VH300 Before you can use your Bluetooth
Aug 18, 2010 | Sony Ericsson VH300 Bluetooth Mono...
The volume button stuck when i wanted to increase volume and now i cant move it . What could have happend. Peltor WS4 blutooth
I have the Headset but my one is the bluetooth in it.
1st thing is if you are using it all day at the end make sure that you pull off the ear covers and take the fome out of it.
This is to let the air get in to dry it out.
I screwed up a pair by not doing this.
Why do this is while your working with them sweat will form in the **** and will get on the the chip inside the ****.
If this happens and over time you dont let it dry it will arck and damage the chip making to work bad or not at all.
If you have had the headset for less then 2years call who you got it off as they do a 2 year warnty on them. If its past that take a look inside the headset. You could send it back if it still does not work after that send it back. But if it is the chip that is gone its best to just get a new pair. As getting the chip but in it can cost more than a new one.
Nov 24, 2009 | Ao Safety PELTOR ALERT M2RX7A Radio
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
Hope this helped.
Nov 18, 2009 | Mad Catz Bluetooth Headset for PS3
Peltor MT53H7AWS2 Bluetooth Headset Logo
561 people viewed this question
Top Peltor Radio Communications Experts
eradiostore
eradiostore
Are you a Peltor Radio Communication Expert? Answer questions, earn points and help others
