Question about Dell E197FP 19 inch Flat Panel LCD Monitor
The monitor wont come on.i noticed the power button has been pushed inside the monitor and i need to know if i can disassemble it to get i tout without hurting the monitor
  • Dell Master
  • 1,684 Answers
The E177fp and E197fp are identical units other than the size of the display panel. Here is a link to a repair guide for the E177fp that has videos showing how to open the unit. It should help you get your open.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-e177fpf-lcd-monitor-with-power-issues/
Posted on Nov 07, 2012
5 Suggested Answers
SOURCE: Power button stuck
The power button on my Dell 1905FP monitor failed with the power turned off. Following the advice posted by Guest: pried the trim panel loose using a couple of small screw drivers starting with the small slots just under the power button. As guest states in his posting, the connecting wire is very short, but does provide enough room to access the buttons lying behind the trim panel. With this access, was then able to press the power button back to the "on" position. Snapped the trim panel back into place. Monitor now works fine, though the only way to turn the power off is to unplug the power cord.
Posted on Jun 29, 2008
  • 11 Answers
SOURCE: 15in dell monitor model e151fpb
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
  • 1684 Answers
SOURCE: Power button stuck in off position on Dell Flat screen Monitor
Does the button move at all? What model LCD is it? Most of the time if the monitor does not power up it is the power supply inside the monitor not the button sticking. The power supply can be repaired if that is the problem. Please let me about the movement on the power button and I can help you get back going with your monitor.
Buddy
Corporate Computer
Posted on Jun 17, 2009
budmrtn
  • 11361 Answers
SOURCE: The power button to the my DELL LCD monitor is
This is very common problem with this series, the plastic actuator is broken off, very cheaply made and poorly design part.
I have lo luck locating this 5-button plastic switch assembly yet.
Be real carefule when separating the front bezel from the bac cover, it has very small ribbon cable attached to the front panel switch assembly that can easily be ripped apart.
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 20, 2010
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
The off/on button is stuck on.
You will have to disassemble and reseat the push button assembly, it is very poorly design.
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20X223W/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Apr 24, 2011 | Acer 22" X223w LCD Monitor
My toshiba p10 wont ower up at all ...NOTHING with or with out battery or cord totally dead .battery went dead when i was useing it and i tried to lug it in to the wall and it just kept on loosing ower...
Have you tried power up the Laptop without the battery installed? Remove the battery and plug in the charger, now Turn On the laptop, if there's no internal problem, it should power up which means your battery is bad, you'd need to replace it.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jan 14, 2011 | Computers & Internet
For turn on my Samsung I have to push power button 15-19 time.Couple months ago I pushed 12 times.Now i have to push 19.
mmarcen2000, If warranty with Samsung not valid option, you or someone will need to fix it!! IT WILL NOT FIX ITSELF!!! Your unit may have one or two things wrong that are a common problem with LCD monitors of ALL BRANDS. Contact Samsung to see if they have a CASH+OLD unit swapout program in effect for your model!!! If DIY is an option you would prefer to do, then check on YOUTUBE for videos that deal with "LCD monitor disassembly" and LCD monitor repair" . Lots of "BLACK SCREEN" lcd owners have done the repairs needed to refurbish their monitors to "working" status for less than $10 in parts. Your monitor's symptom is common to a possible "THERMALLY INTERMITTANT COMPONENT SOLDER CONNECTION" or "BAD, SWOLLEN, LEAKY" electrolytic filter capacitors. You will need to inspect for both if you decide on DIY fix. Do an additional comment to your above post to let us know your plan of action after reading some of my other responses to BLACK SCREEN owners. Approximately 98 percent of my responses deal with symptom of BLACK screen. Also visit other websites listed in those responses. Good luck. 12fixlouie
Dec 28, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Power/Monitor
looks like the power button needs to be replaced.. must be pushed it
Mar 28, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
The power buttom on my Dell E228WFP 22 not working
MY MONITOR JUST WENT OUT AND I GOT 2 RED LINES ON EACH SIDE OF SCREEN SO I UNPLUGGED IT NOW IT WONT POWERUP AND LIGHT IN BUTTON WONT GO ON
Feb 27, 2009 | Dell E228WFP LCD Monitor
My Dell E171FP Is Dead!!
Order new capacitors and replace. I had the same problem with mine and with $4 and a soldering iron I got mine back up and running.
Check www.badcaps.net for monitor repairs...
Nov 07, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Apple Studio Display Flashing Power Button
For the brave of heart, You can disassemble the monitor. After you get in to the inside of it, you'll see a circuit panel with 6 ballast coils on it. On my Cinema display, what happened was that the solder joints on some of those coils had cracked, causing intermittent connection. After hitting all the connections with a soldering iron to heal the cold solder joints and re-assembling it, it is working perfectly fine now.
Jan 29, 2007 | Apple Cinema HD 23" LCD Monitor
Dell E197FP 19 inch Flat Panel LCD Monitor Logo
53 people viewed this question
Alun Cox
