Question about Amana AKT3020 Electric Cooktop
Just turn on by itself and is on when knob is in off position
    Top Expert:
  • Amana Master
  • 9,472 Answers
Which burner is it?
Posted on Nov 07, 2012
SOURCE: Burner light does not go off on Amana AKT3040
I had the exact same two problems with my AKT3040. Both problems were on the dual burner.
1. Problem with the "hot" light always ON was solved by replacing the burner (problem caused by defective temperature sensor), unfortunatley it seems you can't get the sensor by itself these days so I had to change the whole burner.
2. smoke came out from the knob controlling the dual burner: problem solved by replacing by a new knob. You have to be carefull since the replacement knob is a little different than the original part so you have to connect everything properly as per the provided instruction sheet.
Posted on Aug 08, 2008
  • 222 Answers
SOURCE: Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
Posted on Nov 18, 2008
  • 222 Answers
SOURCE: Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
Posted on May 29, 2009
SOURCE: Amana gas cooktop clicks when not in use
Take a look at the solutions that have been posted regarding igniters. i suspect a dirty or wet push-down knob. you will see that others have had water/moisture causing problems. drying mights solve it, but it may need a a bit of a clean. keep trying. it must have taken me a couple of hours to solve.
Posted on May 08, 2010
  • 1891 Answers
SOURCE: Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Posted on Jul 16, 2010
The left rear stove element went on High and would not turn off by controls, why? There was an F550 code that came earlier with the oven?
My range was doing the same thing. I finally called the Consumer Protection Agency and reported it. It launched a national recall. With their help, Frigidaire replaced my range. On Easter 2014, the new one did the same thing. Burner turned on by itself, to 8.5 with knob in the off position. We had to unplug it. Frigidaire once again did not care. I contacted the CPSA again - they are investigating. I will NEVER have another Frigidaire Range. Check your model number against the recall information. Don't trust it! It is a fire hazard.
Feb 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
I saw an answer relating to a problem that has just developed on it's own on my Jenn Air Gas Cooktop regarding a clicking noise. My burner is trying to ignite all by itself and I'm in my bedroom. It's 10...
If you can disconnect the power to the cook-top then do so..this will give you a little peace of mind...it seems like the switch for that burner is defective(eg: stuck in on position)..the switch is an integral part of the control that turns on the gas for the burner..you may need to replace the control assembly..these are available from appliance parts stores and on-line
Jan 22, 2011 | Jenn-Air Cooktops
My gas cooktop has just spontaneously started clicking (as if I were moving the knob to start the burner) on the front two burners. I have tried turning the knobs on and off, but the clicking and spark...
One of your burner switches is stuck in the ON position. On older models the switch itself can be replaced. On newer models the whole bunch need to be replaced. c2c8a4f.jpg
Oct 25, 2010 | GE Cooktops
St George Rotomaster stove/oven turning itself on.
This certanally sounds like a bad switch.
Availablity of a replacment switch I am not shure.
But you can try. Here is a link to service agents that
should be able to help you
http://www.sga.com.au/Services/default.aspx
Hope this helps.
Please leave feedback.
Dec 06, 2009 | Cooktops
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
All 4 burners keep firing although the knobs are in the "off" position
It actually stopped doing it all by itself while we were waiting for a solution.
May 16, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
Amana AKT3020 Electric Cooktop Logo
64 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Ted Maxwell
Paul Carew
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
