How do I wire a Honeywell YCT410B1000 Manual 4 Wire Premium Baseboard/Line Volt Thermostat. I seem to have lost the manual.
My wire to the T-stat is a 10-2 line, white and black in and out. The T-stat has 2 red and 2 black wires
  • tim4sherri
    tim4sherri Nov 08, 2012
    Would I run the pwr IN to one side and pwr OUT to the other subbing white for red>?
4 Suggested Answers
  • 252 Answers
SOURCE: I recently purchased Honeywell programmable
yep- 1 wire to R the othe to W (or W1) dosent mater which is which
Posted on Nov 10, 2009
  • 86 Answers
SOURCE: Im hooking up a base board heater for the first
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Posted on Nov 04, 2010
  • 4 Answers
SOURCE: i have 240 volt baseboard heater need to wire 4 wire theromostat
i have the answer, did you solved it yet???
Posted on Nov 07, 2010
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Reinstalling a baseboard thermostat on wall. two red and 2 black wires in box in wall, plus a connected ground. Older model Honeywell thermostat, niot mercury, with only 2 black wires. Tried several...
baseboard heaters are usually line voltage thermostats. the wire in your box sounds like a 240 volt circuit. either the 2 blacks or the 2 reds and wire nut the others. I dont know if they need to be connected to each other, not sure where they go or what they are to
Dec 16, 2009 | Honeywell Heat/Cool Thermostat
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Jan 26, 2009 | Honeywell Programmable Thermostat Heater
Need to replace 2 wire baseboard thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 13, 2009 | Honeywell (CT62B1015) Baseboard Heater
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Nov 27, 2007 | Ingram GMS90904CXA Heater
Heating & Cooling Logo
845 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
