Question about Aiwa HS-TX525 Personal Cassette Player
AIWA Personal cassette player and Radio
I have just bought this cassette player off Ebay, it came with it's original box and looks in good condition.
When I put a tape in to play it keeps going up and down in speed, like the batteries are running out but I have just put new ones in.
Any ideas out there? Also when I adjust the volume its very crackly.
P.S. It's the TX 457 model
Rgds..
  • 275 Answers
SOURCE: Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
Posted on Sep 25, 2006
Duncan
  • 218 Answers
SOURCE: AIWA CDC-X115
Check BOTH of your power connections and your ground too. Make sure you actually have 12v at each connection and don't have a blown fuse etc. If you are lucky then you will solve the problem. Good luck.
Posted on Apr 30, 2007
welcomejee
  • 10594 Answers
SOURCE: problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Posted on Oct 22, 2008
  • 120 Answers
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Posted on Jan 15, 2009
  • 63 Answers
SOURCE: Have Aiwa NSX-V9090 Stereo with jammed cassette. I
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Posted on Aug 19, 2009
Find manual for AIWA TX377 Tape Cassette Player with AM FM Radio manual
AIWA went out of business and was taken over by Sony. You could try their support page:
Contact Sony Support
There are so many RISKY sites offering user manuals, I'd be very wary of going to them...
Jul 14, 2014 | Aiwa Audio Players & Recorders
How to change belt in walkman wmfx277
there is a good chance you cannot, belts are very hard to get, and if its sony, they are not always easy to get into and often have screws but also have clips, that break upon opening,
its probably better to but a replacment but that too will be hard,
you could try ebay for belt, but it may be better to get a 2nd hand one, or sometime u can get new ones, too
but stay away from aiwa they tend to break down, although offer the best sound, in my opnion
Jun 23, 2014 | Sony Walkman WM-FX277 Personal Cassette...
Have a cassette walkman that will only produce sound on one side of the headphones when jack is put into the outlet for the headphones. i know it's not the headphones because i've tried other ones too...i...
Hi ya
Well Aiwa stereos are very hard to open and designs to break when opening, however some models can be opening without too much issue.
So before you try to open the item, try these if you have some switch cleaner or alcohol tape head cleaner - put a little drop onto the headphone jack and insert and move around the socket just incase there is dirt on the contacts inside, also clean the tape head too just incase of the same,
if not then its an open up, sometime the solders come loose, so with a soldering iron just warm the solders up a little this may fix it.
if this does not it may be a broken part inside the jack - they can be replaced but not easy - spares can be got from ebay from china, for about 1.00gbp
hope this helps
Feb 14, 2014 | Aiwa HS-PS40 Personal Cassette Player
Aiwa TX646 user manual
I suggest search under manufacturer's website, they often keep downloadable pdf versions of the user manuals of all of their products hosted there: http://www.aiwa.com
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 18, 2011 | Aiwa HS-TX686 Personal Cassette Player
Manual for Aiwa TX646
Go to Manualfix.com. If they haven't got it, they'll get it.
How do I get my HS-TX686 to go into continuous auto reverse?
Look in the operating instructions which you would find by searching "Aiwa HS-TX686 manual"
http://www.retrevo.com/support/Aiwa-HS-TX686-manual/id/1077bh447/t/2/
Under "Playback"
Aug 13, 2011 | Aiwa HS-TX686 Personal Cassette Player
How to connect an aiwa music system to sony dvd player
Just plug the audio output of the DVD to audio input(AUX) of Aiwa system. Select the player in the Aiwa( Aux, DvD, and Phono)
hope that helps out!
Jun 09, 2011 | Aiwa Audio Players & Recorders
AIWA CXNMT 520 CD/TAPE/RADIO PLAYER
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Thanks.
Dec 18, 2009 | Cameras
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
Problem with AIWA TP-M130 micro cassette recorder can't get tape out
Oct 22, 2008 | Audio Players & Recorders
Aiwa HS-TX525 Personal Cassette Player Logo
77 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
