Question about Toshiba Satellite A75-S2112 Notebook
When I power up I'm unable to get to the boot menu. I press F2 for safe and F12 but to no avail. Is there a way to get around windows root error? Thank you Jay
  • Toshiba Master
  • 2,878 Answers
The simplest may be to load Windows again, because there are different causes and fixes for this error.
Posted on Nov 07, 2012
Nixcroft
  • 135 Answers
SOURCE: bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Posted on Nov 21, 2008
Fixe_You
  • 1800 Answers
SOURCE: I do not have recovery cds and I am getting error message for win
u need to install a new windows in that comp
Posted on Jun 08, 2009
SOURCE: problem with a corrupt system32\stoskrnl.exe
check out the article given below to view the detailed information to troubleshoot the issue:
http://support.microsoft.com/kb/314477
Posted on Oct 17, 2009
  • 1752 Answers
SOURCE: won't boot up, get the toshiba screen asking to
Your hard drive is probably dead. If you can't reformat it, then get a new one.
Posted on Oct 23, 2009
  • 8909 Answers
SOURCE: hello, the problem with
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Posted on Feb 05, 2011
Reboot Toshiba laptop
Step One: Remove power (either pull the battery or press and hold the power button)
Step Two: Add power (either put the battery back in or press the power button just once)
Step Three: Press F2, F10, and F12 buttons repeatedly one at a time until boot menu screen displays.
Step Four: Navigate to boot options
Step Five: Boot in Safe Mode
Step Six: Once computer has booted properly restart computer.
Step Seven: (If asked, select launch last known good configuration)
If this doesn't work please send more information.
Image of boot menu screen attached
May 04, 2016 | Toshiba Computers & Internet
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
System won't boot up window XP
HI Joe. It's likely you have a virus. Or could be just a corrupted section of the hard drive. The F8 is what gets you to the black screen with the differnt boot options. F2 or Del button gets you in the the BIOS or start up instrutions for the PC. F 12 will get you boot device options. The F12 or F2 needs to be pressed before it ever gets to try starting windows. So when you first power on, immediately start tapping the F12 about once a second. This should bring up a menu of which items/ device, to start from. [If you get a stuck key message just clear it and continue tapping F12 or start over] I would suggest you use the windos CD and choose the CD device to boot from, then it will recognize the CD drive. You could follow the CD start up options to peform a repair of windows. If you do a repair, then you should also perform a virus scan immediately after. If after all that, you still have issues, then it's likely the hard drive itself is bad or going bad and you should look at replaceing it. Good luck.
Dec 05, 2012 | Dell Dimension 8200 PC Desktop
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Aug 26, 2011 | Toshiba Computers & Internet
I tried upgrading my acer aspire 5920g from vista to win7 ultimate, it did load up but the problem is the erecovery it self... i dont have the back up cd to which the error is missing *.wsi file... can any...
Enter the BIOS setup ( pressing F2 on ACER screen Bootup)
Locate 'Main' > Enter
Locate D2D Recovery > Enter to Disable
Exit > Save
Insert Windows 7 Ultimate
Reinstall ( Press F12 > Boot Menu )
akee.4shared.com
Aug 15, 2011 | Acer Aspire 5920-6727 Notebook
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
Bios batt
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Windows recovery problems
If you still have the recovery discs available then press F11 or F12 depending on which one is the boot menu and boot from the CD and reinstall Vista from it onth the hard drive.
Apr 18, 2008 | Acer Aspire 5520-5908 Notebook
Toshiba Satellite A75-S2112 Notebook Logo
14 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
