Question about Vizio SV472XVT 47 in. LCD HDTV
Tv went out no picture no audio no pier light
    Top Expert:
  • Vizio Master
  • 14,553 Answers
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. Tv went out no picture no audio no pier  - 11_7_2012_1_30_12_pm.jpg11_7_2012_1_31_02_pm.jpg
Posted on Nov 07, 2012
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Posted on Oct 23, 2007
  • 7 Answers
SOURCE: Vizio P42HDe Plasma TV - Audio, but no picture
check the backlight inverter and the Y-sus board the one to your left. if those are fine check the bottom right buffer board
Posted on Apr 20, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
  • 18 Answers
SOURCE: No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Posted on Apr 03, 2010
Tv picture problems on Vizio m3d460sr hdtv lcd (back lighting out ?)
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 09, 2014 | Vizio M3d460sr 46 Black 1080p Tv Lcd
The picture went black, but the tv still has audio
The back light inverter board may have gone out, or ir is not getting 24vdc from the power supply module, check those two places.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-32w1+
Jan 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Audio Yes, Picture No
From your description, it could be the back light has 'gone'.
Feb 16, 2009 | Sony BRAVIA KDL-40V3000 Television
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
I have audio but no video...
Deflection Board resolder all Pinns on (FBT) Flyback Transfomer.
Nov 02, 2008 | RCA D52W23 52" HDTV CRT TV
Screen zipped down to dot of light in center and went blank. No audio either
the deflection circuit shut down and i hope it didn't burn the crt's .
Oct 29, 2006 | Toshiba 55H70 55" Rear Projection...
Open Questions:
See all Vizio SV472XVT 47 in. LCD HDTV Questions
Vizio SV472XVT 47 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
