Question about Crosley CR49-TW Tweed Traveler Turntable CD Player
The table won't turn. I have power and can hear the motor, but no turning. Read other suggestion on removing the plate to check the belt, but i can't get mine off.
    Master:
  • 689 Answers
Don,t try, You will just damage it, Take it in for repair,Where they no what there doing. If you damage it then it will be verry costly to have it repaired,
Posted on Nov 09, 2012
3 Suggested Answers
  • 6 Answers
SOURCE: Crosley CR49 Turntable Speed Problem
Do you know how to make a measurement? open your equipment, use your voltmeter to see how much voltage run the motor and then compare with the voltage who is written in the motor. If the voltage which your have read is in the range of motor voltage +- 10% is ok, of no, that voltage must be more than that correct that problem.
If the voltage is the range of motor voltage the replace the motor.
Thank you.
Tell me if this helped you
Posted on Mar 04, 2008
  • 92 Answers
SOURCE: New Black Crosley suitcase record
than a wire or the motor control is bad or not connected
Posted on May 10, 2011
Whirlpool washer won't drain.
A long shot!
With water in the machine and power turned off! remove drain pipe wipe clean and then blow down the pipe you should hear it blow bubbles inside the machine this will prove it is not a blockage.
Also check that where the pipe waste fits into the drain is not blocked?
Is the pump direct drive or driven by a fan belt?
If it is direct drive from its own motor and you can hear the motor running I would suggest that the impeller has come adrift or broken ?
If it is driven by a fan belt check it is still intact and also tight enough!
Sometimes the belt may be in position but slipping when it is supposed to be turning.
Some machines have pumps that run off the main fan belt and would have adjusters or springs to keep them in contact with the drive belt
I hope this is of some help?
Best of luck!
Jun 15, 2013 | Whirlpool Washing Machines
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
Won't spin
Remove the screws from the back side. You can check the belt and if it is ok then your motor is probably burned up. Do you hear the motor running when you turn it on.
Jan 31, 2013 | GE Dryers
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
Dryer heats, but won't tumble. Suggestions?
Either there is no tension on the belt or the motor is not running. If you don't hear the motor, the first thing to check is whether any air blows out the vent. If you have air moving, the motor is OK and you can check for a broken belt or a problem with the tensioner pulley mounted on the motor bracket. First, reach inside the dryer and try to turn the drum by hand. If it turns very easily, belt tension is definitely the problem. If you can't turn it at all and the dryer was previously making a lot of noise, the drum has crashed due to a bad bearing or bushing pad. A stuck drum can also ruin a belt.
On most dryers, you can remove the panel under the door to look at the motor and belt tensioner. Usually you have to take off the floor trim piece way down at the bottom, then remove the screws holding the panel. The top of the panel is commonly held in place with spring clips.
On some models you have to undo screws at the back near the top, then tilt the top up like the hood on a car (there are spring clips holding the front of the top; you may need to pry with a thin piece of hardwood or a screwdriver with tape wrapped around the shaft to protect the paint on the dryer). This gives you access to clips and screws holding the front onto the dryer. If you have a broken belt, you'll need to remove the front (door assembly) anyway to replace the belt or drum bearing. (Some models have a drum bushing on a center pin in the back of the dryer; you can get at these by removing a plate on the back).
If the tensioner pulley has a lot of slop in the bearing, fix this; otherwise the belt may wobble off it again. You'll be surprised by how much quieter the dryer gets.
If the motor is not running, check for a failed starter capacitor (located inside the control panel), a bad centrifugal switch (inside the motor), bad contacts in the timer (control panel), or an open thermal fuse in the motor.
CAUTION: unplug the dryer before doing any work inside.
Jun 06, 2011 | Dryers
Turn table doesn't rotate, Ive removed the plate & checked for motor resistance by turning the drive by hand, there is resistance there (thought it might be belt drive!)
These motors are usually small geared motors. You will have difficulty truning it manually because if the high gearing. The motor could be defective and need replacing. You should be able to access it from under the appliance.
Jan 26, 2011 | Panasonic Kitchen Appliances - Others
My sharp R-953 turn table turns slowly when you put some thing on it ,it stops turning
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 13, 2011 | Sharp R-1870 Convection/Microwave Oven
I just bought a aiwa turntable & stereo at yard sale. the old lady said she never used it but yet the turntable will not turn. i've looked over the manual and can't find any troubleshooting. can you...
Hi Denise, I am in the consumer electronics repair industry. It may be as simple as this... Lift up the MAT on the turn table. This is the black rubber covering that you place the record on. Look through the holes in the plastic turntable (rotate if necessary) until you see the motor/pulley shaft sticking up (brass color). The turntable belt may have dislodged from this pulley. If you see the black flat rubber belt near here, just put it around the pulley again. Make sure it is not twisted and sits flat. Spin table by hand to be sure it is seated properly.
Now you may have to remove the plastic turntable itself if you can't see the belt right away. In this case, remove the C-clip with a flat screwdriver (be sure not to lose it) from the record center post. Lift the turntable plate up shaft. Check to see if the belt is still partially around the plate. You may be able to just see enough to wrap the belt around the motor pulley now. If you need to take the plate off completely, then just place the belt first around the groove on the plate and finese the belt around the motor pulley. Now seat the plate, replace the C-clip and place the MAT back on and it should be good to go.
I had this same problem on a new turntable I got for free. Good luck : )
Oct 17, 2010 | Audio Players & Recorders
I have a delta 36-600 table saw that the clutch or drive has quit working . the motor was rebuilt about a year ago now the drive slips is there a simple or easy fix or adjustment to the clutch for this...
If you have a motor with the no.1313314 and the motor runs ,but the blade spindel does not turn try removing the backcover plate . With this removed you might find that the toothed gear belt has broken. If this ,in fact, is the problem the belt is a Bando syncro,link 100xl.
Hope this rectifies your problem as I am waiting for a new belt myself.
E
Oct 10, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
My sony cdp-cx300 when i turn it on i can hear the motor but the cd turn table doesn't spen and after a min. the digital read out says table error
It would have an error because the table wont turn. If you open it up, you will find that the rubber belt that drives the turntable is broken or worn out. It connects the turn table to the motor.
Nov 27, 2009 | Audio Players & Recorders
Crosley CR49-TW Tweed Traveler Turntable CD Player Logo
69 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
