Question about Magic Chef Kitchen Ranges
Oven temp problem
Oven temp goes up and down
    Top Expert:
  • Magic Chef Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 08, 2012
When I turn the oven down the gas goes off and have to start again
read the user manual as the temp should be thermostat controlled were with gas there is always a pilot light burning when the oven is in use and when the set temp is reached the gas burner is shut off and when the temp fall below set point , the gas is turned on again and the pilot light starts the burner
by using the timer , when the time is reached the gas is turned off and of course you will have to relight it
if you do not have a user manual , download one from google or talk with a gas repair shop
Sep 18, 2016 | Belling Ovens
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
I have purchased a new Homemaker Convection Oven MODEL AOT-F901 from Kmart in Joondalup WA. When I use it the light comes on and off continiously - should this be happening????????
This is normal for the oven. The heating element comes on until the required temp is reached, then switches off until the temp goes down a bit - then it comes on again to maintain temp. Hope you're still enjoying your oven...
Aug 27, 2011 | Ovens
I can't open the oven after I cleaned it
self cleaning ovens stay locked til the temp goes down to a safe temp give it a little time
Apr 15, 2010 | GE JKS05 Electric Single Oven
Rf367lxss oven temp low need to adjust rca whirlpool
MOST OVENS ARE ADJUSTABLE TURN ON BAKE, ADJUST TEMP ALL THE WAY UP AS HOT AS IT GOES, HOLD BAKE BUTTON DOWN UNTIL IT BEEPS AND REGISTERS 0. THEN ADJUST TEMP UP IN 5 DEG INCREMENTS.GOOD LUCK!
ERIC
Jan 21, 2010 | Whirlpool Ovens
Oven burns things, very hot on bottom
The temp indicator light goes on and off according to the temp selected.
The sensor referred to is part and parcel of the the thermostat, or temp selector
the fact the light goes on and off, shows that the thermostatt is working, but neccesserily at the correct temp.I maintain that the thermostat that controls the temp is faulty, and needs to be replaced.
Dec 21, 2009 | Frigidaire FEB27S5A Electric Single Oven
New oven thermostat acting nuts
can't find our model with this model # .. i would try cking the wiring / making shure it's correct . normal orp when heating the light is on . not heating light is off . although the thermo is new it may be bad / or possible that it not the correct replacement . hope this helped **** ..
Dec 09, 2009 | General Electric JBS07M Range
Viking oven only one burner will light
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m20127_f20254.pdf
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Kitchen Ranges Logo
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
