Question about Ctm HS 890 4 Wheel Heavy Duty Power Scooter
Need replacement motor and wiring harness for CTM HS 580
Caught in flood, repairman says it needs new motor and wiring harness
2 Suggested Answers
SOURCE: Need owners manual for A ctm hs 740 mobility
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
Posted on Nov 06, 2011
Need wiring diagram for ctm hs-588 mobility scooter
Here is the manual. I am still looking for the schematic. the manual does have a god troubleshooting section. http://scooterland.net.au/wp-content/uploads/2015/08/User-Manual-HS-589.pdf
Oct 29, 2017 | Ctm Health & Beauty
What is the weight on the batterys
Lead acid batteries are not light but generate copious amounts of relatively inexpensive cost. Our battery technology is at least 100 years old but....................
Nov 18, 2015 | CTM Homecare CTM HS-580 4-Wheel Power...
Wiring diagram for ctm hs 580
hi Linda, sadly you won't get that however i can help as I have rewired quite a few of those,, first of all please ID the controller
Regards
Rob
www.gewizrepairs.co.uk
Jul 17, 2015 | Drive Medical Health & Beauty
How heavy is a ctm hs 580
hi,
Total Weight with Batteries : 197.8 Lbs.
Regards
Rob
Jul 12, 2015 | Ctm Health & Beauty
Ctm hs580
5 flash code indicates your brake. Check your free wheel lever and ensure it is in drive.
Aug 26, 2014 | Health & Beauty
Light is flashing 6 times
Hi,if the controller is a blue finned model called a Rhino, then the following applies...
6 OONAPU Out Of Neutral At Power Up. The throttle was not in the neutral position
when the scooter was turned on. The scooter does not drive.
• Return the throttle to neutral, turn the power off, and back on again.
• Throttle may need to be adjusted (see section 5.1.6).
• Check throttle wiring.
Regards
Rob
And please join me on Facebook https://www.facebook.com/gewizrepairs
May 10, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
Mar 30, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
Ctm HS 890 4 Wheel Heavy Duty Power Scooter Logo
37 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Oloyede Monsuru
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
