Question about Sceptre Televison & Video
Television will not turn on - Sceptre Televison & Video
    Top Expert:
  • Sceptre Master
  • 14,553 Answers
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. television will not turn on - 11_7_2012_1_40_56_pm.jpg
Posted on Nov 07, 2012
Sony Projection Televisions - HOW TO FIX TV Red Blinking light of times between 3-second intervals and turn off
I have a Sony Bravia. Smart Television that would not turn on once in standby mode. The Red light would blink twice. I unplugged the television and reconnected it using a surge protector power supply strip. This solved my issue. From now on I'll be sure to turn the television off instead of allowing it to turn itself off.
May 01, 2014 | Televison & Video
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Tip
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
on Aug 01, 2010 | Philips Magnavox 27MS343S 27" TV
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
The tv wont turn on
please check the power cord of the television,and try another electronic device if it is also not turning on it shows tthat there is a problem with the ACsocket.AND IF IT IS TURNING ON and your television is not turning on So please call the technician for the assistance becouse if you try to do anything with your television it may result of your another loss
Oct 30, 2010 | RCA L42WD22 42 in. LCD Television
My lg lcd turns on.then turns of
Unexpectedly Turning Off
Many LG LCD television owners have reported a problem
where their television will power itself off or will only work
for short periods of time.
The problem usually occurs in brand new televisions and requires
the television to be sent to LG or your local electronics repair
shop to be repaired.
Jan 04, 2010 | LG 32LX1D 32 in. LCD Television
The television turns on then immediately turns
There could be an ic that has gotten blown within.
Let some expert have a look and rate all the ics on board.
Cheers.
Aug 23, 2009 | RCA Televison & Video
My tv keeps shutting on and off
You television is having problems with intermittent component failure. The reason the television turns off and on is the protection circuit turns on when it senses high voltage or current level that may damage the internal circuits. The protection circuit turn the television off, the television will stay in this condition until the faulty component or components temporarily stabilize. When this happens the television attempts to turn itself on again. Once the component or components heats up it loses tolerances and again triggers the protection circuit to turn the television off. This is a problem that should be fully tested and evaluated by a certified service center. You can contact RCA customer support at this telephone number 1-877-947-7977 between the hours of 8am-8pm M-F EST and. 10am-7PM S/S EST. You can also contact RCA customer support on line at this web page link http://tv.rca.com/en-us/ContactUs.html I hope this information help you solve your problems with the television. Thank you for using FixYa and have a nice day!
Jun 20, 2009 | RCA R52WM24 52" HDTV Projection Television
Troubling turning on RCA 52" television
try replaceing CP150 and CP114 on the deflection board
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KDF55WF655
TURN TIMER OFF OR, The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
Jan 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
835 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
