My Sears box tv model 509.14410 has a green tint that goes away after a while.Expensive repair?
If the tv has not been on for a long while it takes longer for the normal picture to return.Once normal it stays normal
  • 308 Answers
SOURCE: Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
Posted on Dec 24, 2006
  • 308 Answers
SOURCE: picture has a green shade
Sounds like your red picture tube is not emitting enough brightness to balance the colors. A temporary solution could be to slightly increase the screen voltage of the red CRT to give a good black and white picture when the color control is turned all the way down. If the set has not been serviced in the last 5 years or so, and you're not ready for a new HDTV set, it may be worthwhile to get a technican to look at it and clean the dust off the lenses and mirror and evaluate whether a picture tube rejuvination might work along with the gray scale tracking adjustments.
Posted on Mar 18, 2007
yankeegurl
  • 121 Answers
SOURCE: samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
  • 197 Answers
SOURCE: Green Tint
bad optical block call sony they have a recall
Posted on Jun 09, 2009
  • 103 Answers
SOURCE: We also have a greenish tint. We put a new bulb in
Your "light engine has possibly gone down on you, did you replace just the bulb it's self or the complete bulb assembly? If you pulled out light assembly and replace just the bulb then repalce light assembly, if you repalced the whole light socket assembly and still have greenish color the you have a "light engine problem". Seek repair tech.
Posted on Oct 01, 2009
How do I repair a green tint on element tv model number PLX-4202B
Intermittent green tint is a source problem. Cable, satellite or HDMI cable.
Jan 02, 2015 | Televison & Video
What would cause my jvc tv have a green tint
It sounds like you can have optical engine issue. That's if green tint was show up very gradually, until one day it really caught your attention.Normally some parts of the screen more green than other. It should get progressively worse. To solve this issue optical engine have to be replaced. It is pretty expensive repair if your TV is out of the warranty.
In case if tint appeared suddenly in one moment - you can try to check component cable connection on the back of your TV if you are using one ( green, blue and red colored). Sometimes it's loose or after disconnection people reconnecting it in wrong way.
Experienced tech will determine if optical engine is bad by running test patterns in special service mode. If green tint present on Grey scale - optical engine is bad.
Sorry for bad news.
Regards.
Russ.
Apr 06, 2010 | JVC AV-56WP74 56" Rear Projection...
Sony KDF 3LCD Screen has a horizontal orange tint stripe at top
This problem is caused by a defect in the optical block. It causes about 1 - 1.5" tint usually green, orange, or yellow at the top of the screen. The part is very expensive, retails around $600-800 usually. You cannot fix it without replacing the optical block. They did have an extended warranties for this particular issue because of a class action lawsuit on certain models. Call Sony to see if your model is one of the ones they extended the warranties.
Oct 05, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
KP-57WS500 turning green or red and then off
Green and Red guns seems defective and requires replacement.
Both guns (CRTs) are no longer available so TV has no worth to repair.
Apr 19, 2009 | Sony KP-57WS500 57" Rear Projection...
A lot of green tint in the picture
Hi, what you do is unscrew and take off the grill, take off the black board behind it. You will see a little box for adjusting RGB you will adjust the screen rgb to get the tint to go away and have a perfect color then you will adjust the focus for sharpness. (reset the tv to factory settings before doing this so that your tint, color, brightness and everything else is in the middle.
Oct 17, 2008 | Televison & Video
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green tint to everything on my Samsung HDTV Digital 1080i television
I have the same problem here on this Samsung 40" LCD. its a 2007 model. everything was fine until recently. I had to reset my digital cable box. now the picture has the green tint. its ruined what was a nice tv, and it won't go away.
Mar 11, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Green Blotches and Bars
I have determined that mine had a problem with the composite input board. I was able to unhook the connections to this board inside the TV, after Akai, and the local repair guys couldn't figure it out....
The problem hasn't come back in a while, and since my setup is all HDMI/Component ins, I didn't affect me at all.
It looked like there was slight heat damage to the board, but not enough that it was caused by a design flaw, more like a manufacturing "accident".
Oct 21, 2007 | Akai PDP4225M 42 in. Plasma Television
WD-52525 too much green and picture is not clear...what can i do to fix it
. Suspect the FMT PCB part # 930B924002. Supect the DM PCB part # 934C116002 if green tint
Aug 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
