Question about Hotpoint Aquarius WMA42 Front Load Washer
Water is leaking out of bottom of hotpoint aquarius wf445 wash ma
Could this be a blocked filter? Where abouts is the filter?
  • smbeau66 Jan 07, 2009
    Thank you barkencoa. Will try your solution over the next couple of days and will than rate you. Once again thanx.
  • Hotpoint Master
  • 3,463 Answers
The filter is located behind the removable rear panel of washer.
Remove panel and on the right side you will see a large black hose, undo clip and remove hose, inside you will see the plastic filter, remove and clean.
Be careful, as their will be water run out when you remove hose..
Refit hose and make sure it is on securely..
Check for any leakage before you refit rear panel.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
Does the hotpoint Aquarius wf445 have a filter as I have water coming from underneath washing machine please help
More than likely it's a leaky pump or a seal that's gone out. If it's overfilling then it could be the water inlet valve. Repairclinic.com has a lot of useful information and they sell replacement parts as we'll.
Apr 13, 2016 | Hotpoint Washing Machines
I have a 97 Chrysler Concorde the car will turn
About a 100 different things.no gas,no combustion,blocked exhaust,no fuel getting into combustion chamber,fuel filter blocked,camshaft not going round,air filter blocked,ie,rag been sacked up into intake,broken wire on ignition or diesel pump,diesel pump got air in system,fuel pump not working etc
Sep 20, 2014 | 1997 Chrysler Concorde
What does a slime block do
You may be talking about what Schneider calls a hydrophobic coating. Schneider uses the coating on their B + W filters to reduce the adhesion of particles and water drops to the filter surface.
Jul 19, 2014 | B&W B + W 82mm UV/IR Blocking #486 Wide...
LOW HEAT, SLOW DRY
  • Hi Jim,
    The first thing to check is the filter is clean and not blocked. The air travelling through the dryer is what carry's the water vapor away. The Lint filled filter will block the airflow resulting in forever to dry anything if at all. The second thing to think about is a over full tub of washing to dry will have the same effect as that blocked filter. Two half loads of washing dry faster that the same amount altogether in the same dryer. Last but not least, check that the intake or exhaust is not blocked with fluff or that the dryer is not right up against the wall effectively blocking the flow of air.
    These points are general to all dryers Jim. They are not specific as you have only recorded a fault and no mention of Brand age or model.
    Good Luck
    Regards
    John
Jan 30, 2014 | Dryers
Fuel not getting to intake
fuel filter blocked or inlet ports are block not hard u can blow out with an airline fuel filter is about 3 pound on ebay or in ur local store
Apr 18, 2012 | 2000 Chevrolet Blazer
2001 CHEVY MALIBU WONT TURN OVER, UNLESS YOU SPRAY STARTING FLUID ON IT, THEN IT STARTS FOR A FEW SECONDS. HOW DO YOU REMOVE THE LINES IF IT IS THE FUEL FILER TO REPLACE IT.
lots of notes in here about overheating cars, everyone wants to replace the thermostat thinking that will fix it, but it never does. likewise lots of folks thinking their fuel filter is blocked solid. it is so seldom the fuel filter. There is a filter on the fuel pump take up before it even gets to the filter so they just are not going to get totally blocked up unless the gas tank is corroding away on the inside. but your issue does seem to be a fuel supply issue. i would be thinking more about the fuel pump or pressure regulator than the filter. have someone check the fuel pressure at the injectors.
Sep 19, 2011 | 2001 Chevrolet Malibu
I can't open my farmville...it always say this domain is blocked...what to do?
Are you using your computer on a network with filtering software (school, work networks)? Quite a number of such organizations use devices to filter such content. Also, if there is filtering software on your computer, it may block some sites on your computer.
Mar 02, 2011 | Computers & Internet
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
383 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
