Question about Waring Blenders
Model 1081 when turned on has high pitched sounds of motor but nothing working an starts to smell like burning.
My blender had a burn smell and doesnt work could the motor be burned?
They don't make them like they used to. The smell could be the windings on the motor or it could be the control board.
Nov 19, 2016 | Blenders
Oster makes a high-itch whining sound
Sounds like the bearing for the blade on the bottom of the pitcher may be in need of replacement.
Aug 13, 2017 | Oster 4094 Designer Classic Beehive Work...
My BBL410 blender started smoking and stalled out. Now it won't run again. Is there a reset switch or did the motor burn out? What are the repair options?
Sounds like motor is burned out. Very few parts left for that model, nothing electrical.
That model is no longer listed on their support site http://brevilleusasupport.com/
Sep 11, 2011 | Breville Blenders
I have a Vitamix Super 5000. I'm afraid I ruined the motor! I tried pie crust in it...the first batch turned out fine...the 2nd batch I started and the mixer turned off. Won't start. I was NOT using...
It's probably fine, those motors are very strong. I'd be looking for something like a wire off or broken first. A motor does not often fail without a lot of heat and burning smell.
Mar 03, 2018 | Vitamix Super 5000 Work Top Blender
My vita-mix just stopped working, there is slight burned smell, I was blending walnut pieces with dates paste. Any suggestions?
If the burning smells like plastic then the walnut shells most likely put too much strain on the motor and burned it out. If the burning does not smell like plastic then you most likely have walnut shell grit jamming your motor.
This can be cleaned out by first ENSURING IT IS UNPLUGGED FROM THE WALL.
  • First remove the canister (if possible)
  • The remove the blade (if possible) check for a build up of grit between the blade and the shaft connecting it to the motor.
  • Check the channel the shaft passes through from the motor for large chunks of walnut shells or date paste.
  • Clean the canister thoroughly with warm water and leave it to soak overnight in a water/soap mixture.
If this has not resolved the issue then try to claim it under warranty or source replacement parts online.
Feb 28, 2011 | Vitamix Super 5000 Work Top Blender
Burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
May 25, 2009 | Waring BB160 2 Speed Blender
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Burning smell
That burning smell was possibly the motor windings burning out. If the windings have burned the blender will need to be replaced. Hope this has helped you today,.......... Sea Breeze
Please let me know if this answered you question.
Feb 01, 2009 | Hamilton Beach 52250 BlendMaster Ultra...
Blenders Logo
160 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
