Question about Intel Computers & Internet
RAM Upgrade I have an IBM 8122 model system ! it has P4, 3.06 Mhz & 915G chipset ! I contacted lenovo support and they said it supports 400Mhz FSB RAM only ! While on contacting local retailers, they say it supports DDR 400, DDR2 400 and DDR2 553 fsb RAM. the DDR2 400Mhz one is only available at lenovo support. costs 4000 bucks for 2GB while the DDR2 553 MHz is available everywhere at just 1200 bucks ! what should i do ? lenovo support says that it wont work properly with 553MHz while retailers say it supports 553. what to do ? what should i purchase ?
  • biswadeep Jan 05, 2009
    thanx but i got 533 Mhz FSB 2x1GB RAMS.
    what you said is incorrect.
    Intel 915G motherboard supports both DDR and DDR2 and its the only motherboard that has this feature.
    Source :
    Intel® 915G Express Chipset
  • biswadeep Jan 12, 2009
    nope...it has that divider in the mioddle.
    as DDR and DDR2 both have a divider in the middle.
    i searched google for the exact difference in looks !
    but in my board, both are supported.
    it came fitted with DDR 333 Mhz fsb. Worked gud
    Now i put 2x1GB DDR2 533 MHz fsb. It works gr8 !
    and both had different slots as shown above.
    maybe the key hole in my board is a bit large that supports both !
    even i cant make out as all 4 slots look the same !
  • 39 Answers
Let them install it for you. Go for DDR2 667. If it works, gret, if it doesn't scale down... But DDR2, and DDR 400 aren't nearly the same, they won't fit onto the same system, as their pin configs are different.
If the DDR2 doesn't fit, you'll have to go for the more expensive DDR 400.
Posted on Jan 05, 2009
  • Beeuwen Gerryts
    Beeuwen Gerryts Jan 07, 2009
    Ok... interesting indeed. :) i stand corrected. I am curious as to how these RAM slots look. I'm guessing it doesn't have the normal divider on the board itself somewhere in the middle of the ram slot?
    :::goes to google with a curiosity twinkle in my eye:::
Dell dimention 2350 socket 478 I upgrade celeron 2.0Ghz to pentium 4 3.0Ghz 530 The Bios show me the speed 1.5Ghz. Bios A02
The Dell Dimension 2350 Desktop PC motherboard, has an Intel 845GL motherboard chipset,
mounted to it. (System Information),
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1101572
Here we see that the Intel 845GL chipset supports processors, with a -> maximum <- Front Side Bus of 400MegaHertz, (FSB = 400MHz max.),
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Intel Pentium 4 model 530 (3.0GHz. Also has Hyper-threading Technology. HT), operates with a FSB of 800MegaHertz, (FSB = 800MHz),
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
(Scroll down. Pentium 4 HT 530 )
You can't make the Intel 845GL chipset support a processor with an 800MHz FSB.
BIOS update or not, the voltage range will be too low. Therefore the FSB is low. Changing just the Multiplier will not do the trick either.
(BIOS Setup, Advanced Chipset Setup. Doubt the options of changing the FSB, and/or Voltage, and/or Multiplier, is available with that BIOS program))
Note your 3.0GHz processor is operating at 1.5GHz?
Max FSB supported is 400MHz, and your Model 530 needs 800MHz? (For max operation)
Post additional questions in a Comment.
Regards,
joecoolvette
[ Chip and Chipset are shortened terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset technology used for your computer, has a Northbridge chip, and a Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors )
The Northbridge chip handles the faster capabilities of a computer.
Processor, Ram Memory, and High-speed graphics.
[ The AGP technology, and the PCI-Express technology, is High-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics, is NOT High-speed graphics ]
The Southbridge chip handles the slower capabilities of a computer.
Anything connected to the PCI bus, (Such as a PCI graphics card)
IDE (PATA)
SATA
USB
Ethernet
Audio (Sound)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[ CPU stands for Central Processing Unit. Another term used is Microprocessor, or Processor for short ]
So it is first up to the Northbridge chip, of the motherboard chipset, whether it will support a certain processor, THEN if a BIOS update will help.
Nov 12, 2011 | Dell Dimension 2350 PC Desktop
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
Hey All, THIS IS URGENT. My PVCLE266M-L V3.0a will not boot into any OS. I have 2 identical boards. I can navigate BIOS on both of them with the DDR400 512MB RAM stick I have put in. (The specifications...
Your mainboard PVCLE266M-L does not support the DDR 400 Mhz RAM (PC3200) ie @ 400Mhz frequency. For the memory specfications it support "2 x 184-pin DIMM sockets support two2.5V DDR SDRAMs (DDR266)" maximium is 2GB or DDR PC2100 ie @ 266Mhz frequency.
PC133 is the SDRAM so it will not fit the DDR RAM slot.
You should not use the 400MhzDDR memory RAM on a Mainboard with a FSB(Front Side Bus) of 133 Mhz and the 400Mhz DDR Ram is not compatible with the mainboard.
Get the DDR 266 with double side chipset i.e.DDR1 RAM (DDR PC2100) RAM and it will be compatible with your mainboard. Sometimes single side chipset DDR1 RAM will not work on older mainboard.
Hope it helps.
Jul 10, 2011 | Mercury Computers & Internet
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
I have ATXmodel intelceleron1.2Ghz cpu1.2 cache 256KB Intel 810E chipset motherboard can i upgrade my processor to pentium 4 and ram to 512mb
No, u can't. ur motherboard is designed for pentium III processors with FSB -133 MHz, Socket-370 type. Pentium 4 processors have 400 MHz FSB, 423 Socket at least. But yes for memory, u can upgrade it to 512 MB.
Sep 26, 2010 | ASUS Intel 810E Chipset CUWE-RM...
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
How do i change the memory bus speed on my dell optiplex 170l? The CPU is an Intel Celeron 2.4GHz. The mother board processor speed is 400MHz and the Bios indicates a memory bus speed of 266MHz and does...
You checked in the right place as far as looking in the BIOS, however, memory and CPU sockets do not necessarily have the same buss speed. My FSB runs at 1066Mhz and my RAM at 800Mhz, it all depends on what type of RAM you buy as to the bus speed. You can up the bus speed on your RAM if you wish to reduce bottle-necking, but I've only done that a few times. In order to adjust anything, you must set the settings to manual. Be careful when you change this stuff around though, voltages must also be adjusted accordingly.
Feb 28, 2010 | Dell OptiPlex 170L PC Desktop
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
Upgrading Processor & Graphics card
The Intel® 845G chipset is optimized for the Intel® Pentium® 4 processor supporting Hyper-Threading (HT) Technology†. It is designed with the high performance 533/400 MHz system bus and integrated high-speed USB 2.0.
Max Cpu
Pentium 4 2.8ghz with a 400mhz FSB and
Pentium 4 2.63ghz with a 533mhz fsb
pay close attention when getting your cpu if it has a 533 front side bus and is faster than 2.63 then the actual cpu speed will end up slower (you will see something like 2.1ghz) if it comes on due to multiplier limitations
Dec 14, 2008 | Computers & Internet
Computers & Internet Logo
168 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
