Question about Hardware & Accessories
Lost instruction sheet.
It is 120 ac hard wired in.
  • 5,245 Answers
Copy following links to help identify timer:
http://waterheatertimer.org/Boxtype.html
Posted on Nov 07, 2012
Need wiring instructions for power supply kw7.6 208y/120,120/240 60 hz ac 3 wire
There is usually a wiring diagram on a sheet of paper folded and poked inside of the range somewhere (usually by the burner switches). Sometimes it is on a sticker on the back or inside the back panel.
Apr 05, 2013 | Kitchen Ranges
R house doorbells, lighted house numbers on same circuit
Most door bells that are hard wired to a curcuit breaker or other power supply have a transformer, 120 volt ac to 24volts ac. It would take an electrician to test the transformer to see if you are getting the proper voltage into the transformer and out the other side being 120 v ac in and 24v out. The house numbers may run off of the same transformer. If you are not a certified electrician,do not try to fix this problem yourself. All power must be turned off at the breaker box. I hope I have been of some assistance. Better safe than sorry.
Apr 02, 2013 | Cars & Trucks
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
Oct 11, 2012 | Macally G-S350SUA 3.5" Hard Drive...
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
My hard drive lost my gamertag and wont recover it, what happened? what can i do?It's 120 GB elite console
Go to the Xbox Live sign in and scroll over until you see "recover gamer tag" and follow the instructions.
Jul 26, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
My granddaughter has lost my instruction manual for my Zune 120.
por error borre la informacion de mi reproductor zune 120 negro como puedo reintalarlo?
Apr 25, 2010 | Microsoft Zune JS8-00001 Digital Media...
New computer/ Lost Seagate operating instructions
Just plug it in and the pc should detect it as a external HDD and show up as one of the drives. You can copy all the data to it and transfer it to your new PC.
Apr 21, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
What is the voltage of the coffee roaster? Will it go up to 220v? Nesco CB-1010PRP
No most if not all North American units are hard wired for
120 volts . But there's solutions ,got to radio shack
and buy a power converter 120-220 ac not sure of the cost,
you may have to shop around to get a good price.
Jul 03, 2009 | Kitchen Ranges
Airbag light flashes 3 times then 6 times then stays on
This is for the driver's side air bag.
This may be due to a high resistance or poor connections in the side air bag (SAB) wiring harness circuits or restraints control module. This condition may occur on vehicles equipped with, or without, side air bags.
Ford has a Technical Service Bulletin out on this no. 03-24-1.
To service, install an overlay harness which incorporates soldered terminals and tin wiring. Refer to the service procedure for direction on which side air bag kit to order. Installation instructions and illustrations are included in the kit.
FOR VEHICLES WITHOUT THE (SAB), FOURTH DIGIT OF VIN IS "Y" OR "Z" :
  1. Install a new Non-SAB wire harness kit 3L2Z-14B455-AB. Refer to the installation instruction sheet included in the kit.
FOR VEHICLES EQUIPPED WITH (SAB), FOURTH DIGIT OF VIN IS "C" OR "D" :
  1. Install the appropriate harnesses as indicated below. Refer to the installation instruction sheet included in the kit.
    • 1999-2001 4DR Limited Explorer XL2Z-14B455-DB
    • 1999-2001 4DR Explorer (except Limited) and Mountaineer XL2Z-14B455-AC
    • 1999-2000 2DR Explorer XL2Z-14B455-BC
    • 2001 2DR Explorer 1L2Z-14B455-AC
Apr 17, 2009 | 1999 Ford Explorer
Ac wiring problem
as a general rule ,only if your ac was a window unit. aka a 120 volt unit . all other acs use 240 volt. a 120 leg and a 120 2nd leg to equal 240, so there is really no common. what kills acs with a generator is the lack of watts and starting torque. an ac (3 ton) and up needs a generator of 10000 watts minimum to handle starting trque. they also need a hard start kit to boost starting voltage.for god sake someone reply and tell me what a good job i am doing!!!!!!!as in grade the response to your question.
Oct 17, 2008 | Dometic Rooftop RV Air Conditioner
Hardware & Accessories Logo
18 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
