Question about HP Pavilion DV6500T Laptop
My CD/DVD compartment cannot work
If I slot in a CD or DVD, it rolls but cannot show even when check the My computer. I searched the Device Manager from the Control Panel on line for solution, but that it has been upgraded, but possibly currupted. The installed device is HL-DT ST DVDRAM GSA-T20L ATA
  • binaqua1 Jan 10, 2009
    Just cannot enable it. Even when I did scan it for any virus attack, it still did not give me the functionability. Please help me! Thanks.
  • 41 Answers
Right click on my computer-->select device manager-->check cd/dvd rom there. If it is disabled there, please enable.If this doesn't help,contact me.
Posted on Jan 05, 2009
  • gowthamk
    gowthamk Jan 11, 2009
    1.now follow the steps I've mentioned earlier.
    2.clean your dvd ram's lens by using any cleaning disk(best to use dry type)
    3.re install the operating system
    4. uninstall dvd drive, remove the dvd drive and re insert it and re install it.
I hv an e machine E725 n the dvd/cd driver is not working what could the problem
Try to Update or Roll Back the driver in Device Manager, DVD/CD-Rom drives. You can find the drivers for the DVD/CD Rom here, select your OS: http://support.emachines.com/em/driver/nb/e725.html If you could explain further what happens when you put in a CD? Is the DVD/CD Rom Icon showing it Computer folder?
Mar 09, 2013 | Computers & Internet
Resource conflict PCI in slot 01 bus 1A device 04 function at startup and then the DVD player doesn't show up under device manager
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 19, 2011 | Computers & Internet
I formatted a CD from my Gear Head Mobile Slim CD/DVD R/W removable drive. The drive shows up in all of the following: (1) My Computer, (2) the Device Manager, and (3) the task bar's removable devices. But...
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 23, 2011 | Gear Head 8X DVD MOBILE SLIMDRIVE W/...
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
Error with a TSST CD/DVDW TS-L532U.
Try uninstalling the device using device manager. Shutdown computer and restart. If the problem persists then you have a faulty DVD/CD drive.
Go to My Computer and right click, select the Device Manager, search for the drive on the right side. Right click and choose Uninstall. then restart. Hope this helps.
Jun 13, 2010 | Computers & Internet
Optiarc dvd rw driver shows code 19 error .i have tryed to reinstall ,but no use.
The below step will surely resolve the issue..
CD/DVD drive in device manager and the CD/DVD properties in device manager shows error code 10 , 19 , 31 , 32 , 39 or 41, please use the following steps:
This issue occurs due to an incorrect registry entry, which might be created due to installation of an incompatible CD/DVD burning program. We will remove the registry entry and re-install the CD/DVD drive and the issue will be fixed.
1. Click on Start and type regedit in the search box and hit enter. It will open Registry Editor window.
2. It will open registry editor.
3. Click on File and Export, it will open a new window.
4. Select Desktop from left pane in the new window and put file name as regbackup and click on Save.
5. It will create a back up of the registry on desktop.
In case something goes wrong during modifying registry, this registry backup can be used to restore to original registry.
6. Now in registry editor click on triangle symbol next to the following items in the left pane:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
7. Locate 4D36E965-E325-11CE-BFC1-08002BE10318 below class and click on it. Make sure you have selected the correct entry as all the entries looks almost similar.
8. Look at right pane and check if you see UpperFilter and LowerFilters entries.
9. Please right click on UpperFilter and LowerFilters and select delete.
10. make sure there are no other UpperFilter and LowerFilters entry in that window.
11. Close registry editor.
12. Now please click on Start and type device manager in the search box and hit enter.
13. It will open Device manager window.
14. Click on + sign near CD/DVD entry and it will show the name of the CD/DVD drive with a yellow mark near it.
15. Right click on it and select uninstall.
16. It will remove the CD/DVD entry from device manager.
17. In Device manager, click on Action > Scan for hardware changes to re-install CD/DVD drive.
18. Now you should see the CD/DVD drive entry.
19. Do you see any yellow mark near it now?
20. Please click on Start > Computer and check if CD/DVD drive is listed.
21. Please insert a CD or DVD and check if the computer reads it.
May 08, 2010 | Computers & Internet
Acer L100 dvd drive is not sencing any dvd or cd. so I can not write any thing
Go to Device Manager and see if your DVD is listed among all your computer's hardware and peripherals.
(type "device manager" in your COMPUTER search area if you don't know how to get there)
If it IS NOT listed-power problem or defective
If it IS listed, right click it, select PROPERTIES
(Yellow triangle indicates error)
First tab GENERAL shows if it is working properly.
Then click on DRIVER tab to see if you just need to update the driver, or roll back to a previous driver.
Hope this helps.
Feb 20, 2010 | Acer Aspire L100 PC Desktop
I couldnt watch any DVD movies in my LG X NOTE RD405
Hi
> Go to my computer check for the dvd drive
> Check in device manager under cd/dvd drive for the dvd icon if it is not showing
> Go to run -type - regedit
Search for the upperfilter and lowerfilter registry through find option and delete the registry and reboot the system and check for the status
> If dvd drive shows the optical drive uninstall by selecting the optical drive from the device manager
Apr 02, 2009 | Computers & Internet
DVD drive on Toshiba Satellite M35X-S311 not working
Ooops! Hate it when I delete necessary stuff !!! Go into the device manager and uninstall the optical drive (cd/dvd drive), then reboot. It should find the drive and reinstall it. If it doesn't, then do a hardware search from the device manager. If it still doesn't find it, then do a system restore to a point before deleting the files.
Jul 15, 2008 | Toshiba Satellite M35X-S311 Notebook
Cd-rom
Check it from Device manager;
Right Click my computer. Go to properties.Hardware tab; Device manager; See under device manager ! any yello sign; ETC;
If you could not find any alternate Best Solution is try replacing CD DVD Rom
Regards
Rafique
Mar 17, 2008 | HP (PR017UA) PC Notebook
HP Pavilion DV6500T Laptop Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
