Question about Carrier 38CKC042 Air Conditioner
My carrier air con is only blowing cold air and i need the hot
It blows out the cold air but when i put it on the heat setting it is still only cold what could be the problem. My husband could fix it if he knew the problem. im sorry i only know that it is a carrier, the main units are on top of the apartment blocks and we have it vented, with a little control unit in the apartment
  • 700 Answers
It sound like the heating sequecer maybe have gone bad on the fan coil unit that you have. You need to call the maintenance personnel that does the work where you live or a service company out to repair the unit because since y0u only rent it is their responsibility to provide youp with heat and if by chance that you have a heat pumo unit then you definately want them to get on the roof to fix the problem. Remember to always change oyur filter inside when ever you get your electric bill because even though it's theeir unit it's your electric!
Posted on Jan 05, 2009
No heat blowing cold air
Heater blowing cold air? - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan.../233563-heater-blowing-cold-air.html
Nov 5, 2006 - 15 posts - ‎6 authors
... it idle, all guages normal, heater on HOT and HIGH, it blows cool air. .... thatNissan put out for some reason (I have no idea where it went to, ...
How To Fix Your Car's Heater - YouTube
? 3:03
https://www.youtube.com/watch?v=bmmn4ON_t0c
Nov 26, 2009 - Uploaded by Scotty Kilmer
... Scotty Kilmer shows how to fix your car's heater for those coldwinter ... How to Diagnose and Fix No Heat Issues - Also a Demonstration on ...
maxima blowing cold air while idling - Maxima Forums
maxima.org/...maxima.../599527-maxima-blowing-cold-air-while-idling....
Sep 21, 2009 - hello everyone, i have a 2004 nissan maxima sl. when the car is warmed up and the car is idling the heater will blow cool air, but when i am driving. ...Not sure whats involved in a heater core for the Max, but I had to pull the ...
Jan 15, 2016 | Halonet 95-99 NISSAN MAXIMA / 96-99...
Blows heat on passenger side only . Blows cold air on drivers side only
A nice radiator and heater core flush should fix you up.
Nov 17, 2014 | Cars & Trucks
Kia Sedona- center and third row heating vents blowing cold air
This model has a rear heat/cold blend door actuator. Its an electric motor that moves the duct door from hot to cold. When they wear out, they're usually stuck on the last setting
Nov 13, 2013 | Kia Cars & Trucks
2007 Chevy Silverado dual climate control, even if passenger side is not on it blows cold air on passenger side and hot on driver side when in heat mode, also noticed cold air on driver side when A/C is on...
Just had this happen today to my 2007 silverado heat on the right side cold air on the left side. After engine was off 15 minutes and restarted heat was on both sides. I'm guessing a relay failed to open door to allow the heat to flow thus blowing cold air.will monitor diligently for a while.
Oct 20, 2010 | 2007 Chevrolet Silverado Classic SS New...
Hi! I have a 2006 Saturn Vue 4 cylinder with 91,000 miles. I always keep my AC on max. The other day I turned the temp warmer. Well the next morning the AC stopped blowing cold air. I noticed before...
The car will idle funny due to the air-conditioner on ,when on it takes power from the motor about 10-20hp depennding,and with the air on all the time its robbing you of fuel mileage.put the temp back to cold and use norm-air max should be used to get real cold and then switch to norm.if you want warm air,then put on vent and stop wasting fuel,with a.c on when you have it on the red area.
Aug 29, 2010 | Saturn Vue Cars & Trucks
2001 Daewoo Nubria heater stopped working and is now overheating
CHECK COOLANT AGAIN IF IT GET LOW HEATER WILL STOP BLOWING HEAT.
Jan 10, 2010 | 2001 Daewoo Nubira
Heater blowing cold air, 4 babies really need heat....
Your heater core could be blocked. Check the hoses going to it on the inside of the engine compartment. There will be 2 5/8' heater hoses going into firewall adjacent to one another. The tempature of these hoses should be almost the same after your van has reached normal operating tempature and your temp select switch is on hot(heat). If not it's a good idication your heater core may have some blockage in it. You would then have to flush it out or replace it. Hope that helps.
Nov 03, 2009 | 2000 Dodge Grand Caravan
No hot air & sometimes no air at all
my 2000 dodge caravan heat sometime working sometime not working
Oct 17, 2008 | 2000 Dodge Caravan
Carrier 38CKC042 Air Conditioner Logo
116 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
