Question about Gateway 702GE PC Desktop
Need start button switch - Gateway 702GE PC Desktop
  • Gateway Master
  • 5,660 Answers
Posted on Nov 07, 2012
On button does not hold starting circuit.when start button is released drum stops turning
when you hit the start button it sends power to motor the start switch on motor is bad some modles you can replace motor switch but most of the time you need to replace motor
Mar 03, 2015 | Dryers
Tip
Dryer when start switch pressed no start but buzzes
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
on Mar 01, 2015 | Dryers
I have Hotpoint Ultimate Extra WD72 washer dryer and the start button has stopped working any idea if this is an expensive problem ??
When you close the front washer door, it closes a switch. This switch prevents the washer from operating when the door is open. Your problem is when you close the door, the switch does not go into the closed position. Now when you press the start button, nothing happens. It acts as if the door is in the open position, even though the door is closed. The door switch is defective and needs to be replaced with a new one. Some start buttons only momentarily close and use a relay type of switch to keep power going to the washer. If you have this type of start button, then the relay/switch could be defective. This is a separate part, it is not the start button switch. It is also possible that the start button switch is defective. So up to three parts need to be checked. None of these are expensive repairs.
May 26, 2014 | Washing Machines
Tedx640jq1
On most dryers in the US, there is a removeable metal panel behind the top of the control panel that is fastened on with some screws. With the machine unplugged, take the metal panel off, and you will see the inside back of the start button. The start button switch is often held in place with 2 screws. Remove the knob on the front if you need to, and then change out the switch.
Remember, it is more likely the door switch is bad if it will not start than the start button. The door switch breaks much more often than the start switch.
Be blessed.
Jun 21, 2013 | Dryers
Lg2277hw - sometimes the start button works very easy on the 1st gentle push- other times I have to repeatedly push the start button - eventually it starts - sometimes it starts but then I get the de
If the door switch contacts have burnt out then the switch will never work and neither will the machine until the switch is replaced. If the door switch button is worn then it will need replacing. If when you switch the machine on and it does not start, try giving the door a "shove" or "gentle thump" in the door latch area. if the machine then starts it will no doubt need a new door switch. if it does not start then the main ON/OFF button or the door switch will need to be checked. Both these components take the full power of the machine as long as the machine is running so they are prone go faulty. Unless you are comptent with electronic components I can not explain how to do this for safety reasons.
Apr 14, 2012 | LG WM-2277HW Front Load Washer
Tw 200 starts with a push,but wont start off button.Battery OK seems like a fuel problem.please advise.
If it was fuel it would not start with a push.
I think you have a bad switch. Now you will need to have bike in Neutral. Remove button switch turn key or power switch on. Take a wire and jump a cross switch. If the bike starts replace the switch.
May 17, 2010 | 2001 Yamaha TW 200
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
When i push the start button motor does not start
Ok, you have narrowed it down nicely and, this leads my to believe that you will need to replace the start button switch. this start button switch circuit board is damaged.
May 31, 2009 | Magic Chef CYE4000AWW Electric Dryer
Faulty Start Button?
If the dryer doesn't even start to turn when you press the start button, then you have to look at a couple things; The start button itself, the starting relay or the safety circuit. You mentioned that there's a ticking sound... if this sound goes away when you open the dryer door but comes back again when the door is closed, then the safety circuit is working.
It could be the switch itself or the starting relay (if equipped with one). If you're mechanically capable, consider looking at the relay. See if the contacts are being pulled in when the start switch is pressed (DANGER: HIGH VOLTAGE). If it is, the start switch is OK.
Hope this helps.
Apr 02, 2008 | Dryers
Gateway 702GE PC Desktop Logo
15 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
