Question about Archos 605 WiFi Digital Media Player
Horizontal lines across the screen, locks up
Also the device isnt holding the charge, format hdd screen appears, cant do anything with it. It has been charged all night, as soon as Itake it off the dock the machine has pixelled screen
Sent back to Archos to fix/replace
Posted on Jan 06, 2009
Would not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 05, 2013 | Cell Phones
Horizontal Lines appear across my laptop Dell InsironE1505
really? that would suggest a bad lcd or video chip...
Mar 18, 2008 | Dell Inspiron E1505 Notebook
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Horizontal lines have appeared on the screen?
Its either because you dropped it some where or its because u charged it with some other charger other than the specified one. There are 2 solutions for it one is leave the ipod unused/untouched without any charge in it for 4 to 5 days. If u still get the line appearing on the 6th day then the only solution is to get it opened n try alligning the screen else replace the screen.
Thankyou
Jul 31, 2009 | Apple iPod MA446LL/A MP3 Player
My sansa screen went white
Try resetting the device by holding teh power switch in the ON position for about 15 seconds, then while it's OFF, slide the power switch DOWN to the HOLD position. Now for the tricky part, let's force a manual MSC connection. Press and hold the center button while plugging in to the USB port. Let us know if the screen lights, and the battery begins charging in this mode. If it's charging, let her charge for a while to give the battery a chance. Then, open a Windows Explorer window. I like to use [Windows key] + E, or go to My Computer. See if the Fuze appears under "devices with removable storage". If it's communicating, you have the options of formatting the device and reloading the firmware.
Jun 06, 2009 | SanDisk Sansa Fuze MP3 Player
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Canon ZR200
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Oct 06, 2007 | Canon ZR400 Mini DV Digital Camcorder
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Archos 605 WiFi Digital Media Player Logo
71 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
