Question about Whirlpool GD5SHAX Side by Side Refrigerator
"pipe hammer" from water line to in door ice/water dispenser
Raised the bar to stop ice maker and tried to drain the water line by turning off what appears to be an on/off switch that protrudes from the grill in the front on the unit but that didn't solve the problem... ended up having to unplug the unit to stop the noise
Whirlpool UltraEase Water Filtration System Service and wiring sheet # 2255373REL
Thanks for your help!
  • 700 Answers
Try to turn down the valve that feeds your refrigerator water inlet to see if that can help. It's most likely that you have too much water pressure feeding the unit and the valve is having a hard time closing off the flow of water. Good luck and have a Happy New Year.
Posted on Jan 05, 2009
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
The ice maker isn't working. There is no water in the line.
I have a similar problem for my LSC27911ST. There is no water coming out from the dispenser, although ice maker seems to be working.
I didn't do anything other than keep trying water dispenser in hope that water can be drawn out from the inner pipes.
After opening the freezer door a number of times, tried dispense ice and then tried dispensing water a number of times, eventually water come out again.
Maybe the water line in the refrigerator was frozen. It is very hot today, and maybe the refrigerator over work too much.
Jun 13, 2010 | LG LRSC-26922 Side by Side Refrigerator
My Whirlpool refrigerator Model # ED5RHEXNL00 Ice maker broken
Hello. Thanks for choosing fixya! The most common cause for your problem is that someone accidentally raised the wire in the icemaker area that turns it off. Check that first if the wire is up, push it down and within a few hours you will have new ice. The second most common problem is that the cubes in the mold got stuck in there. the fix is to use a blow dryer to free them up, then dry out the mold and spray some PAM cooking spray in to the mold to lubricate it. The final possibliity is that there is ice in the water supply line that feeds your ice maker. Once again get out the blow dryer and thaw that ice so that the water flows once again. good luck with it. regards, joe
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Will not make ice, water line is connected and turned on, and water dispenser works fine.
HI,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Jul 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker in Kitchen Aid stopped making ice
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Whirlpool GD5SHAX Side by Side Refrigerator Logo
271 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
