Question about Yamaha RX-V520
My receiver only plays inputs plugged into 6CH INPUT
I can only watch peripherals plugged into the 6CH INPUT. If I plug the DVD player into DVD input or a game into AUX Input, I only get the sound with no picture. Let me know Thanks
robotek
  • 1512 Answers
SOURCE: Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Posted on Feb 16, 2008
  • 151 Answers
SOURCE: Yamaha RX-V363 input settings
HI,you are not getting picture because the yam 363 dose not upscale or convert the picture from the composite input to hdmi.You will have to put a video cable from the composite out put on the amp to a scart convertor into the tv or put console picture into the tv and sound to the amp.
hope this helps.
CABLE GUY.
Posted on Jul 17, 2008
mlapres
  • 757 Answers
SOURCE: No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
Posted on May 08, 2009
  • 6 Answers
SOURCE: How do i connect my ipod to a Denon receiver? The
de los cables macho- hembra tienen una entrada como de audifonos y las salidas en modo RCA blanco y rojo con 2 entradas conectalas en cualquier entrad posterior de tu ampli ya sea cd o en alguna auxiliar que diga play ok. saludos
Posted on May 02, 2010
tbreeze47
  • 3083 Answers
SOURCE: Receiver is automatically switching back
This is most likely due to an IC, and could be a heat related problem, or a relay being switched on and off, or both in unison.
You can take the unit apart, and try spraying electronic cold spray on parts, until the unit stabilizes, and then you'll know which part is heat sensitive. Concentrate on spraying the ICs, transistors, and discrete components. Go slow, and allow the cooling to take effect.
Other than that, it's going to be a signal fault, and could be due to a cracked or cold solder joint, worn relay contacts, or some other tricky thing that will have to be troubleshot with specialized equipment.
Also check your connections to your speakers, and the internal solder joints on the jacks, rca connectors, etc.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
Nothing on screen when DVD inputs are plugged into our Aquos.
Check that the input you are plugging the DVD into on the TV is actually selected as the TVs input. Try using a different input and also different input types/cables. Most DVD players will have HDMI and also either component or composite type outputs. Try the different cable type and make sure the TV is looking at the correct input. Do you have sound?
Feb 11, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I need to hook up my Kenwood vr-207 to a satellite HD receiver and blue ray player. How do I hook up the component cables. I am not sure where to plug in the "in's" and "outs".
In's always go to Out's.
The VR207 has no component video inputs, just a composite video output so you can use your TV for the receiver's On Screen Display.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/vr207.pdf
Just run your BluRay and Cable box HiDef HDMI, component, s-video, composite video, whatever (in that order of preference) to a matching input on your TV or monitor.
As a rule you should run the best audio from each of your video sources to the VR. There is no compelling reason to ever send good audio or video to a device that has little (or no) use for it.
Unfortunately, the VR207 has no digital audio inputs, so the best it can muster regarding surround is Dolby Pro Logic derived from 2-channel inputs.
BUT, if you have a DVD, BLURAY player or cable Box with 5.1 analog outputs you can let their internal circuitry decode Dolby Digital programming to true 5.1 for input ("DVD/6CH") to the VR207.
Feb 05, 2011 | Kenwood VR-207 Receiver
I have a 50 incch samsung tv with samsung surrond sound/receiver/dvd player. I have no voices when we play a dvd but the music plays what is wrong
You need to have the audio from the DVD player hooked up to the same input path on the receiver.(if your running video thru the receiver) DVD audio should be hooked up to either an analog input (RCA cables) or Digital input like Digital Coaxial or Optical. Next to where you are plugging in these cables will be writing like "DVD optical" or "DVD digital". Then, make sure you switch the input of the receiver to "DVD" then it should work fine. If you still have problems post a comment and I will help some more. Hope this helps
Jun 14, 2009 | Audio Players & Recorders
Curtis DVD 5091 Home Theatre System
I believe I have the solution....but it depends on your dvd player's zuxilarily capabilities. Do you have a second set of OUTPUT plugs that are colored Red and White on the back of the TV? Do you have a separate Red and White INPUT plugs on the back of the dvd? The TV must use the speakers in the DVD system by pushing the sound OUT. You cannot accomplish this if the dvd is only pluged into the INPUT of the tv.
\Another option is o make sure your DVD player has a "auxilary" or separate input channel on the console or remote.
I have a DVD home theatre system as well, not the same brand, but that shouldn't make a difference . Its a matter of how the sound is received.
Hope that helped.
Apr 29, 2009 | Curtis DVD5091 Theater System
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Jun 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Yamaha RX-V520 Logo
35 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
