My carrier air conditioning unit is blowing only cold air and i need the heat what could be the problem
  • 700 Answers
Either the outside unit has a tripped high pressure switch or the indoor heat is malfunction and youneed to call for a qualified service personnel to come out and repair the prooblem for you .
Posted on Jan 05, 2009
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
Why is ge ajes12dcc 11600/11400 window air condition/heater combo blowing cold air for heat the air conditioner is working fine but the heater is blowing out cold air
Hi, it sounds to me like your reversing valve is not switching the flow of freon over to heat, stuck in cooling. The valve is located near the compressor, it has a 24 volt coil on it. If you unplug it, it should switch the valve into heat. If not, the valve is probably froze stuck, and will need to be replaced. Something a service tech would have to do.
Shastalaker7
Nov 06, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
A/c works heating blows cold air
Is this an electric unit? I guess it is. It appears tha the heating elements are not activating. Check to see if the contactor pulled in on a call for cooling>
Oct 20, 2009 | Carrier YC273D Air Conditioner Window/Wall
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
My carrier air con is only blowing cold air and i need the hot
It sound like the heating sequecer maybe have gone bad on the fan coil unit that you have. You need to call the maintenance personnel that does the work where you live or a service company out to repair the unit because since y0u only rent it is their responsibility to provide youp with heat and if by chance that you have a heat pumo unit then you definately want them to get on the roof to fix the problem. Remember to always change oyur filter inside when ever you get your electric bill because even though it's theeir unit it's your electric!
Jan 05, 2009 | Carrier 38CKC042 Air Conditioner
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
